Results 1 to 4 of 4
    The FABRICATOR!
    Jul 2011
    southern illinois
    Default 2017 LTX Shootout Modified PA Rules
    Modified Power Adder
    Qualifying, Ladder, and Tree Information
    Limited to quickest 16 qualifiers. Sportsman Ladder. .400 Pro Tree
    Vehicle/Body Rules
    Open to all year, make, and model vehicles. All vehicles must be stock bodied and stock appearing.
    Minimum race weight including driver 3000lbs.
    Engine & Drivetrain Rules
    Must have LT1 based engine (Factory LT1 Block). Cylinder heads must retain the factory 23 degree valve angle, Trick Flow 21 degree heads permitted (TFS-30400008-M54). Aftermarket heads and converted small block Chevrolet heads will be permitted if they follow the above guidelines.
    Aftermarket EFI PCM, LS1/24x PCM conversions, and Carburetors are allowed with a 100lbs weight penalty.
    Gasoline or E85 Only.
    Rear mounted batteries must be mounted and vented per NHRA specifications and have a functional disconnect switch.
    Any GM transmission allowed. Torque converters not permitted with manual transmissions and clutch activated automatic transmissions are prohibited. Line locks, trans-brakes and two-steps allowed. Throttle stops, delay boxes, and auto shifters prohibited.
    Any automotive rear axle permitted.
    Power Adders
    Only one power adder from the following allowed:
    Nitrous: Maximum number of one stage permitted. Nitrous and fuel solenoids must be visible. Purge must exit engine compartment. NHRA permitted bottle heating only.
    Supercharger: Maximum YSi or F1A. Roots style superchargers limited to 1575 cfm. Supercharger compressor wheel must be constructed of cast or billet aluminum. Exotic materials prohibited. Meth Injection Permitted
    Turbo Single: Maximum 88mm inducer and maximum T6 flange. Turbocharger must be of conventional impeller and housing design and type. Turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic materials prohibited. The tips of the impeller wheel may not be stepped, cut down, or notched to meet impeller tip to tip dimensions. Reducers prohibited. Anti Lag systems Prohibited. Meth Injection Permitted.
    Turbo Dual: Maximum 60mm inducer and maximum T4 flange. Turbocharger must be of conventional impeller and housing design and type. Turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic materials prohibited. The tips of the impeller wheel may not be stepped, cut down, or notched to meet impeller tip to tip dimensions. Reducers prohibited. Anti Lag systems prohibited. Meth Injection Permitted.
    Wheels & Tires
    Any automotive wheel permitted. Tires must have a maximum height of 30 and a maximum tread width of 10.5 for bias-ply and radial tires.
    During competition passes, all vehicles will be required to weigh after each pass. Vehicles under minimum weight will be disqualified.
    Will cages be checked throughly?
  3. The Following User Says Thank You to shownomercy For This Post:
  4. #3
    The FABRICATOR!
    Jul 2011
    southern illinois
    I'm going to need more information on your setup....
  5. The Following User Says Thank You to firebird_1995 For This Post:
  6. #4
    Mar 2009
    IN
    Ignore me, I can't read.
    Changes to rules are looking good.
