Results 11 to 20 of 30
01-12-2017, 07:59 AM #11
Problem 1. Car ran for 3 mins then died and now it only cranks.
Solution 1. As already stated check fuel pressure then report back.
Problem 2. No tools
Solution 2. Rent tools at local Auto Parts Store to test fuel pressure.
Post up what you find out and Good Luck!355 LT1 Turbo, Ported TFS heads, LE Ported Intake, LE cam, 80lb inj, Dual pumps 340 & 320lph on e85, etc.....
www.fquick.com/SleepyZ
The Following User Says Thank You to sleepy_z For This Post:
01-12-2017, 09:48 AM #12InActive Member
- Jan 2017
- tray stinson
- 1995 roadmaster sedan
- 15
Got you
01-12-2017, 11:35 AM #13InActive Member
- Jan 2017
- tray stinson
- 15
Dont have money right now to get pressure checker. But I smell gas iut the pipe and see sime exhaust. But my a and d terminals on my icm harness has no volt.
01-12-2017, 12:04 PM #14
01-12-2017, 12:08 PM #15InActive Member
- Jan 2017
- tray stinson
- 15
O ok ciol
01-12-2017, 12:09 PM #16InActive Member
- Jan 2017
- tray stinson
- 15
How do u check the coil
01-12-2017, 12:59 PM #17
01-12-2017, 01:14 PM #18Xtreme Member
- 7,269
01-12-2017, 01:44 PM #19InActive Member
- Jan 2017
- tray stinson
- 15
Ok checjed a and d terminal on harness going to icm I have no volts coming from a and d. I do for b and c though. Put car in diognostic mode.
And agot codes under 03.... they were 61 62 161 and 162Last edited by bigontray; 01-12-2017 at 03:55 PM. Reason: wrong nunber
01-12-2017, 04:35 PM #20LTx Guru
On the ICM, pins A and D are 12V DC, supplied by a fuse. Check the fuse. On an F-Body it's under the hood... don't know about the B-Body.
Pin C is a ground. It should not have any voltage on it (if you put one lead of the meter on pin C, where did you put the other lead?). Measure ohms from pin B to a good ground. Should read close to "0" (key off).
Pin B is the pulse signal from the PCM that tells the ICM to fire the coil. Did you measure it with the engine cranking? You have to measure that with the AC Volts scale. What value did you get?
http://shbox.com/1/4th_gen_tech2.html#opti_test
What year PCM are you using? 2-digit codes would appear to be OBD-1. OBD-2 are 3- and 4-digit codes.
How did you put the PCM in diagnostic mode? What scanner did you use? DTC 61 is for the A/C system, there is no DTC 62 for an F-Body, is there one for a B-Body?Last edited by Injuneer; 01-12-2017 at 04:42 PM.
