Thread: Bad Luck!
    Sep 2016
    Brandon Reitz
    1995 Pontiac Trans Am
    Default Bad Luck!
    I took my car out for the first time this year Friday evening. Everything was going good, but after I got off the highway I heard dragging. I hop out and seen my muffler dragging on the ground. I had to wait for it cool off then yanked it off the hanger and had to ruin my car cover by using it to wrap my muffler to get it in the car and home.
    Then when I get home I smell antifreeze. My steam pipe hose off the radiator has a pin hole and coolant was everywhere! My steam pipe is rusty too. I'm looking for instructions on/if the steam pipe can be replaced with AN fittings / SS hose. I researched it and want to ask the experts here. Some are saying the threads are straight threads and a 90° fitting won't work. Not sure, any help is appreciated thanks.
    Bad luck on the exhaust failure and the car cover loss.
    About the steam tube, it can be done. I did it on an LT1. I ran a 1/4"NPT tap into the heads to chase the threads a bit and help cut a little taper into them, then used teflon tape on regular 1/4"NPT fittings. I just used some stuff I had in my shop to do mine. You could do it with fancy braided stainless too. I do know it will be a really hard area to get to in a 4th gen f-body. You'll lose a significant amount of skin from your hands and arms. Here is a photo of how I did it on a swapped LT1 at post #66
    http://www.ltxtech.com/forums/showth...-Pick-Up/page7
  3. The Following User Says Thank You to JOATMON For This Post:
  4. #3
    Sep 2016
    Brandon Reitz
    I was talking to Sean on here and this should work instead of having to tap it as this is 1/4-18 npsm. It should clear firewall?
    https://www.holley.com/products/plum...arts/940006ERL
  5. The Following User Says Thank You to brarei200 For This Post:
  6. #4
    That's the fancy way I spoke of. I've seen some photos of it done in braided stainless line, but can't say on the amount of clearance. I just remember alot of bleeding from cuts and scrapes while trying to break loose some rusty stock steam line bolts in that tight space on my Camaro.
    Nolan
  7. #5
    Sep 2016
    Brandon Reitz
    Okay thanks, I talked to a guy at work and he said a really easy way would be to cut the steam pipe where it's not rusty and run a line from there to the radiator.
