Results 1 to 10 of 21
Thread: turbo?
09-12-2008, 10:27 AM #1
turbo?
Im looking to do a turbo on my car. the thing is I have no idea what setup to use or even if my car can handle it and if it can how much can i handle. heres a list of a few things if have.
355 LT1 . 360 rwhp
Ported and polished stock heads, intake and throttle body.
LT4 hot cam with 1.6 RRs.
.030 forged pistons
SLP ceramic coated shorties.
Stock y-pipe and cats.
Borla catback.
Trifecta tune.
Tuned up less than 500 miles ago with TR55s.
Drivetrain
New Spec stage 2 clutch and billet flywheel
new poly trans mount
Strange S-60 with 3.73s, 35 splines and detroit true trac.
Speed inc nitro drive shaft
B&M shifter
thought about getting longtubes and or lloyd elliot LE2 heads first and get rid of that hotcam. Any suggestions? thanks tomborn with LTX in his blood!
09-12-2008, 12:48 PM #2
Do you know what compression your motor currently has?
96 TA WS6 - 383ci + T76 = no traction
www.lt1boost.net ... your home for LTx turbo kits
09-12-2008, 12:57 PM #3Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
chances are with a NA 355 you are still 10.4:1 or more.. the motor (even if forged) wont last that long under boost as high compression will start to detonate at a much lower boost level resulting in your pistons frying
09-12-2008, 01:51 PM #4
so i guess forced induction is kinda out of the question?
09-12-2008, 02:17 PM #5Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
Unless you plan on changing your pistons, you wont get away with any more than 5-6 psi safely, some people run 9 on stock motors but they dont last long, find out your CR and then we can be more specific
09-12-2008, 02:25 PM #696 TA WS6 - 383ci + T76 = no traction
09-12-2008, 11:56 PM #7
If you can even get the compression down to around 9.5:1 you should be in good shape to run a fair amount of boost. One warning boost is very addictive.
Ben...1994 B4C Camaro restomodding in progress ...
1995 T/A (wife's)bolt-on's,cammed, full bmr suspension
RX7 lt1/700r4 build under way a.k.a. "Kiss my rice" build
09-13-2008, 12:10 PM #8
I dont plan on running alot as it will be pretty much a cruiser. Iv only put 4k miles on in 5 months.is there a way to find out my compresion ratio ? iv got most of the reciepts but cant find the ratio. i found the part # for the pistions. can i find it out with that?
09-13-2008, 01:13 PM #9Pr0jekt Turb0?
- Ryan
- 1993 Camaro Z28
- 3,605
we need the pistons, deck height of the block, chamber size of the heads and thickness of the gaskets, bore and stroke
09-13-2008, 01:26 PM #10
