Results 1 to 10 of 13
Thread: Dedicated fuel system issue
06-12-2016, 03:20 PM #1Lurker
- Apr 2009
- Rob Warrick
- 95 Camaro z28
- Lexington NC
- 549
I been having trouble with the dedicated fuel system I have set up. It's a 1 gallon cell located where the washer fluid used to go. I have a line coming from bottom of the tank to the pump out the pump to the Holley 803 regulator and from there to the solenoid my issue is it doesn't build pressure when I turn the pump on. It doesn't have a return line but I didn't think that regulator needed a return. The pump pumps strong when I disconnect lines idk what to try next. Sometimes if I turn it on and off a few times it'll build about 2 pounds of pressure
06-12-2016, 05:53 PM #2The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
It looks like that regulator is only rated for 4.5-9 psi. How much pressure are you needing?
06-12-2016, 06:12 PM #3Lurker
- Apr 2009
- Rob Warrick
- 95 Camaro z28
- Lexington NC
- 549
Was hoping for 6-9 and jet it appropriately but I can't seem to get any
06-12-2016, 06:34 PM #4Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
06-12-2016, 06:48 PM #5The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
^ That'll definitely do it, especially on a smaller volume tank
06-12-2016, 06:49 PM #6Lurker
- Apr 2009
- Rob Warrick
- 95 Camaro z28
- Lexington NC
- 549
There is and I've tried it with the lid off the cell
06-12-2016, 06:55 PM #7Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
06-12-2016, 07:09 PM #8Lurker
- Apr 2009
- Rob Warrick
- 95 Camaro z28
- Lexington NC
- 549
I believe this pump is jegs brand equivalent to the Holley black pump. I just got it to replace a different one to try it as a fix. The line comes from the bottom of the tank. The pump is a little higher than the fuel but it should be able to draw it
06-12-2016, 08:47 PM #9The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
How much higher is the pump above the tank?
06-12-2016, 08:56 PM #10Lurker
- Apr 2009
- Rob Warrick
- 95 Camaro z28
- Lexington NC
- 549
12" maybe.
