Results 1 to 10 of 21
Thread: First Testing w/nitrous
04-25-2016, 02:54 PM #1
Finally made it to the track for first time testing with nitrous. Car ran perfect but I need to adjust a few things like suspension, tire pressure, colder plugs, and more tuning for my 9.9 ET goal. All in all a great learning session and not bad I ended the day with a 10.24 @130 MPH for a new best. Oh yeah, tires were spinning off the line so I didn't turn the nitrous on till after the 60ft mark. 150 shot BTW.
04-25-2016, 03:12 PM #2InActive Member
- Nov 2014
- Walter Devine
- 1996 Z28 2002 Z28
- Rowletts, Kentucky
- 341
Nice runs, Car is looks good.
96 Z28 LT1 stroker, cage 9 inch, spray 10.24@134.58 1.54 60
02 Z28 edge converter, LTs, lid, cam, spray 12.0@112N/A
The Following User Says Thank You to waltsfastz For This Post:
04-25-2016, 03:51 PM #3
Nice runs, some fine tuning should net 4-5 mph? was that Sunday? I was thinking about the valley all day sunday, seemed like perfect weather.
The Following User Says Thank You to gmpowered For This Post:
04-25-2016, 03:51 PM #4The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
sweet
The Following User Says Thank You to zooguy For This Post:
04-25-2016, 06:21 PM #5VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Awesome!!
04-25-2016, 07:08 PM #6
Thanks guys, no this was on Saturday.
04-25-2016, 08:25 PM #7LTXTech Sponsor
- Feb 2009
- Brad
- 1979 Monte Carlo
- Moscow Mills, MO
- 1,061
- Blog Entries
- 1
Congrats!
2013 King of Street & ES/PA Champ
1979 Chevy Monte Carlo 383,Stock Ported Heads, 4L80 with Edge converter, QP 9", Nitrous Outlet Plate Kit
Certified Performance & Auto Repair Inc.
The Following User Says Thank You to 79LT1Monte For This Post:
04-26-2016, 12:05 AM #8LTX Master
- Nov 2008
- Enrique
- 93 Z28
- Houston/Clear Lake
- 615
Great times. I'm really interested in your engine build now. I can't find anything on it on this site, but I have noticed you have done a lot of test and tuning with the suspension.
The Following User Says Thank You to 383z For This Post:
04-26-2016, 05:42 AM #9"The Rock"
Great numbers man! Ur almost there!
OWNER/ADMIN
04-26-2016, 07:43 AM #101995 TA: Converted Nose...381 LT1...4L80E...Moser 12 bolt...Edge TC...
