Results 1 to 6 of 6
Thread: Injuneer come in
03-30-2016, 09:01 PM #1The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Injuneer come in
Injuneer i was wanting to know about you trans setup.
i am doing a TH400 swap and looking at 4.11 gears ... how does that 3+1 setup hold up94 Formula "budget build" #thebeaterbird
03-30-2016, 09:09 PM #2Xtreme Member
- 7,267
Supporting Member3+1? Wtf does that mean? 4l60e? Here, even though you've been here long enough, I'll tag @Injuneer for you.
03-30-2016, 09:11 PM #3VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
He has a gear vendors over drive unit if im not mistaken = 3+1. :-)
The Following User Says Thank You to dawdaw For This Post:
03-30-2016, 09:55 PM #4LTx Guru
Correct.... Built TH400, reverse pattern manual valve body, with a Gear Vendors 0.78:1 O/D, Strange 12-bolt with 4.11 USA/Strange Pro-Street gears.
Very reliable, but unfortunately, has spent more time on the dyno than on the track. The GV came out of George Baxter's 9-second 30th SS convertible, then in another guy's (John McMullen) 9-second 25th T/A. Took a lickin' and keeps on tickin' !
The GV is capable of splitting all 3 gears, so I guess technically it's a 3x2 rather than a 3+1, but I never used it as anything other than a "4th" gear.SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
03-30-2016, 09:59 PM #5Xtreme Member
- 7,267
03-30-2016, 11:23 PM #6The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
