Results 1 to 2 of 2
12-02-2015, 12:15 PM #1LTXTech Sponsor
- Jan 2013
- 01 Chevy Corvette C5/05 Dodge Ram 1500
- United States
- 296
COMETIC LT1/LT4 92-97 GM MLS Head Gasket, Each
• Provide maximum sealing performance for today's high output engines and require no sealants
• Ideal for aluminum heads to aluminum blocks and aluminum heads to cast iron blocks withstanding the shearing force created by the two materials.
• No need to re-torque, the embossing design of the MLS gasket promotes an even clamp load across the sealing surface allowing for measurable reduced bore distortion
Cometic MLS Gaskets are comprized of multiple layers of stainless steel due to it's increased strength, ability to rebound and resistance to corrosion.
The outer layers of the gaskets are embossed and coated on both sides with Viton - a flouroelastomer rubber based material that is heat resistant to 250°C /482ºF. Viton is designed to meet the demands of a variety of harsh sealing environments, load conditions, and surface finishes.
Click on the link and be sure to select your Bore and Thickness.
$83.00 Each, plus shipping.
The center or shim layer is uncoated stainless steel layer which can be varied to accommodate multiple thickness requirements.
Applications:
GM LT1/LT4 92-97 (Gen II)
http://shop.american-powerhouse.com/...PHCMGC5645.htm
12-21-2015, 01:31 PM #2LTXTech Sponsor
- Jan 2013
- United States
- 296
