Page 110 of 112 FirstFirst ... 1060100106107108109110111112 LastLast
Results 1,091 to 1,100 of 1116
  1. #1091
    Forgot to post this yesterday...
    Hows this for some oil pressure!?!?!?!
  2. #1092
    All loomed up amd rucked away...Resized_20200717_193451.jpgResized_20200717_193518.jpg
  3. The Following 2 Users Say Thank You to popo8 For This Post:
  4. #1093
    Dec 2011
    Louisiana
    That oil pressure is perfect in my book. Some don't like to use high volume, high pressure pumps looking for every single HP they can get, but I say put a high volume/pressure pump to insure the engine.
    '57 Chevy 3100 p/u LT1/T56
    Wife's '94 Z28 has been sold.
  5. The Following User Says Thank You to JOATMON For This Post:
  6. #1094
    Aug 2013
    JB
    Atoka,TN
    Almost Shootout ready! Just in time
  7. The Following 2 Users Say Thank You to Cathead For This Post:
  8. #1095
    Dec 2011
    Mark
    Altoona, PA
    Boom!
    Still alot of work to be done... but first time since Sept of 2016 since the camaros motor has run!
    Sounds really good. Congrats man!
  9. The Following User Says Thank You to 1QUICKZ28 For This Post:
  10. #1096
    Thanks all... im really excited hearing the camaros engine back to life.
    To do list:
    -wire in 6al
    -install proper coil and icm
    -instal blower, figure out piping and intercooler.
    -install guages.
    -longer wheel studs on rear
    -switch out in tank sending unit... current one has failed in showing fuel levels.
    -send back to body shop for front end reinstall.
  11. The Following 4 Users Say Thank You to popo8 For This Post:
  12. #1097
    1994 Chevy Camaro z28
    IL
    Looks good and sounds great! Congrats!
    S60 rear
  13. The Following User Says Thank You to Flyinz For This Post:
  14. #1098
  15. The Following 4 Users Say Thank You to popo8 For This Post:
  16. #1099
    Sounds good!!
  17. The Following User Says Thank You to Ltconvert For This Post:
  18. #1100
    Nov 2008
    1994 Trans Am
    PA, USA
    You must have been thrilled to hear it running, to say the least. Can't wait to see this thing in action!
  19. The Following 2 Users Say Thank You to harner For This Post:
