Page 105 of 112 FirstFirst ... 55595101102103104105106107108109 ... LastLast
Results 1,041 to 1,050 of 1116
  1. #1041
    To my knowledge there is no push lock PTFE.
    there is, it is blue and expensive as shit. popo i would double check the hose you have is rated for fuel, not for hydraulic applications (there is an sae number on it, if its 100d its hydraulic, not fuel rated)
  2. #1042
    It is FUEL line...
  3. #1043
    It is FUEL line...
    not if it is this stuff... https://www.pro-touring.com/threads/...c-hose-for-efi
    i just dont want to see the car burn down. i have to make fuel lines too on the third gen, and have been researching this exact topic almost daily, because fire scares the shit out of me. trying to help man.
  4. #1044
    Rubber hose with no PTFE will break down due to the lovely govt subsidized corn we have in the fuel these days. Just keep an eye on things and if they start to smell of fuel, time to replace em.
  5. The Following User Says Thank You to shownomercy For This Post:
  6. #1045
    It says right on their website that the lines that we used a re fine for fuel... same lines I used in the camaro for over 10 years and not one issue.... thanks for the concern all...
  7. #1046
    ABS removed... line lock installed... new lines starting to be made to bypass where the ABS fell in the system.Resized_20200116_140321.jpgIMG_20200116_211347_166.jpgResized_20200116_190335.jpgResized_20200116_190351.jpgResized_20200116_200420.jpgResized_20200116_200408.jpgResized_20200116_200344.jpgResized_20200116_200332.jpg
  8. #1047
    Just to add, if they do not say they comply with the spec Shaun pointed out then the fuel they comply to is 100% gas. Toss ethanol in there and their rating goes out the window.
    I am sure you will be fine, just sharing some info.
  9. The Following 2 Users Say Thank You to shownomercy For This Post:
  10. #1048
    Thanku
  11. #1049
    Sep 2014
    Joel
    Colorado
    Making good progress.
  12. #1050
    Harness for dual fuel pumps, "created," modified and installed. Just need to wire up the ends at the pumps.20200118_143905.jpg20200118_150924.jpg20200118_160929.jpg
  13. The Following User Says Thank You to popo8 For This Post:
