Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: blower cam?
  1. #11
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    Do you mean stock LT4 springs or the springs from the LT4 Hotcam kit? They're junk either way and cannot control heavy LT1 valves on a NA Hotcam motor. Add boost and it will be a disaster so you'll definitely need better springs and pushrods. If the rockers are from the kit then I'd run them (they are made by Crane).
  2. #12
    The rockers are chromoly comp cam rockers. What would you recommend for valve springs
  3. #13
    Apr 2012
    Mike
    Conshohocken, PA
    Are the rockers promags?
    I would find out if those Brian Tooley springs with the tool steel retainers will fit. They seem like a great deal for $239 and the retainers are only marginally heavier than titanium. A Hotcam is pretty mild and you won't be running much boost with stock compression anyway so I think 150lbs @ seat would work, if not you could always shim a hair more. I know it says the guides have to be machined on the BTR site but the kit is rated for .650" lift and you are nowhere near that. I'd ask a tech if it's necessary (although I doubt it). There should be adequate retainer/seal/guide clearance with a Hotcam but it doesn't hurt to ask.
    If not then hit up Lloyd. He can get you a decent deal.
  4. The Following User Says Thank You to Catmaigne For This Post:
  5. #14
    Aug 2012
    Eastern NC
    XE 224/236 on a 114 lsa. .535/.555 lift
    Proven cam that's been around for years. If you ever do a boost oriented build on the motor then I'd recommend a higher-lift version of the same cam.
    Cayenne Red Metallic 1997 Z28 M6
    Bolt-ons, AI H/C/I, Hooker LTs, chrome ZR1s, etc.
    406/385
  6. #15
    Lloyd specd @Ltconvert a 226/239 .565/.587 112 LSA cam for blower. Thing sounds awesome and made 490 hp na on a engine dyno 383
  7. #16
    Thanks for the help . I will use the lt4 hot cam for now and get a blower cam for the 383 I plan on building with a spare block I have.
  8. #17
    Jun 2014
    Rhett
    1996 z28 vert
    Jackson MI
    I have the btr dual spring kit and it pulls to 6700. The guy that did my heads was very impressed with them. I am still on a stock bottom end.....
    96 z28 vert, 6spd, Ported heads & intake, AI 226/234 110deg, S-trim @ 9#'s, custom 4" intake, Kooks, GMMG, 24x. 507rwhp before 24x, 570 after. Tuned by TJ at Baker Engineering
  9. #18
    LTXTech Sponsor
    Sep 2010
    Red Oak Tx
    BTR is going to start selling the DBL spring kit any day now. He was gonna start machining his own retainers since that was hold up before I believe.
    BTR donated some stuff to the LTX shootout so I wanted to give them a plug and let you guys know he will have spring kits shortly.
    I am a dealer for them and can sell their stuff at a good price or just call them for a good product at a good price.
    Lloyd
  10. The Following User Says Thank You to NightTrain66 For This Post:
