Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
    Default The Unicorn: Round Duex
    Vids and what not will arrive late for meow.. here.
    658hp/753tq at 15psi, no meth, 6200rpm, peak torque was ~5k rpm
  2. The Following 3 Users Say Thank You to shownomercy For This Post:
  3. #2
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    When boost hits, shit got real! Thought you were a little over 16lbs?
    17 Corvette Z06 - 11.05 @ 125
    17 GMC Sierra Denali Dmax
  4. The Following User Says Thank You to blackbirdws6 For This Post:
  5. #3
    Depending on how hard he smacked it, the initial spike was 18, and fell to 15 area
  6. The Following User Says Thank You to shownomercy For This Post:
  7. #4
    The FABRICATOR!
    Jul 2011
    southern illinois
    Nice power curve. Going to keep from spinning it above 6k?
  8. The Following User Says Thank You to firebird_1995 For This Post:
  9. #5
    No sense in spinning it higher, out of cam, out of head and out of turbo
  10. The Following User Says Thank You to shownomercy For This Post:
  11. #6
    The FABRICATOR!
    Jul 2011
    southern illinois
    I'd rather keep it below 6k myself anyway
  12. The Following User Says Thank You to firebird_1995 For This Post:
  13. #7
    I'm happy to have such a low rpm motor, winding things out sucks for a street car
  14. The Following 3 Users Say Thank You to shownomercy For This Post:
  15. #8
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    Since SNM is currently on cloud 9, below is the dyno vid I tossed together.
  16. The Following User Says Thank You to blackbirdws6 For This Post:
  17. #9
    Dec 2011
    Mark
    Altoona, PA
    Very nice! Sounds awesome. Gonna be a fun, fast, tire shredding street car.
  18. #10
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    Pt88 and bigger cam time!
    Congrats on getting it sorted out. Should scoot down the track
