Results 1 to 10 of 12
Thread: Water Pump Spacers
06-18-2015, 04:12 PM #1The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Water Pump Spacers
I've had a few people ask me about water pump spacers over the last couple of weeks, so I thought I would see how much interest there is and having another batch ran off. I would need a minimum of 10 orders. Would be $110 shipped
These will only fit f bodies with radiators stood up, but will fit in b bodies unmodified. For electric water pumps only. 15 minute opti changes ftw.
Let me know if you are interested.
06-22-2015, 04:35 AM #2The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
Bump. No interest yet. I'll give it until the end of the week.
06-23-2015, 12:19 AM #3
I be interested in a set
The Following User Says Thank You to Mav383 For This Post:
08-27-2015, 09:12 PM #4Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
Do you have a picture of how the radiator look in an fbody?
08-28-2015, 01:18 PM #5Moderator | Founding Member
- Nick
- 1994 Camaro Z28
- Lakewood (LA), CA USA
- 728
The Following 2 Users Say Thank You to McCauleyWB For This Post:
09-01-2015, 04:24 AM #6Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
Thanks for the posting the pictures of a ( B body or fbody)
I'm having difficulty picturing how this is going to work. I have an orginal 96 z28. I cannot tell the difference in the way the radiator is installed. I'm getting ready to install a ewp and if that is the factor mounting direction. That would be sweet to be able to add the spacers and be able to do an opti swap in 15 minutes. I already have to modify my electric fans shroud to allow the ewp to clear the electric fans. Do to my current cooling system being stock and mounted in Stock location.
Please correct me if I'm wrong. This is my first ewp in an 4gen fbody.
Sent from my SM-N915V using TapatalkLast edited by Camaro96; 09-01-2015 at 04:33 AM.
09-01-2015, 01:13 PM #7Moderator | Founding Member
- Nick
- 1994 Camaro Z28
- 728
It's an f-body (94Z). These spacers simply will not work with the factory radiator leaned back. As you mentioned, it generally takes some trimming of the fan shroud to get an EWP to work. The spacers are another 1.25" on top of that. There are a couple videos in the following thread to help you visualize the process:
http://ltxtech.com/forums/showthread...hange-the-opti
09-01-2015, 09:17 PM #8Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
Thank you McCauley WB for the links.
09-03-2015, 03:00 PM #9Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
@firebird_1995
Did you make another batch of these? I may be interested in a set.96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
09-04-2015, 12:26 AM #10The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
No I didn't get enough interest but I have a set left over from a build
