Results 1 to 10 of 23
Thread: is my 4l60e going out,
04-16-2015, 11:24 PM #1InActive Member
- Aug 2014
- christopher
- 1996 Camaro Z28
- Central Point, Oregon, United States
- 146
ok so I got in my car today and when I started it was making weird rattle sounds and another sound that sounds like a leaking exhaust gasket. Well I put it into gear and it didn't move. I put it in reverse and pushed the gas and bo movement, just weird sounds. Same with the other gears. The fluid smells pretty burnt but isn't dark. I'm going to change the fluid and filter this weekened. Can a clogged filter cause this?https://youtu.be/GgXXyhrgmBY
04-17-2015, 11:11 AM #2InActive Member
- Apr 2012
- 1994 Camaro Z28
- Orleans,IN
- 300
Sounds like the pump failed. You figure a clogged filter would have gradually degraded, not just all of the sudden.
04-17-2015, 11:28 AM #3InActive Member
- Aug 2014
- christopher
- 1996 Camaro Z28
- 146
04-17-2015, 12:34 PM #4Xtreme Member
- 7,266
Supporting MemberFYI when I blew the pump it just went *tick* then nothing. No other noises.
04-17-2015, 01:33 PM #5InActive Member
- Aug 2014
- christopher
- 1996 Camaro Z28
- 146
04-17-2015, 01:35 PM #6Xtreme Member
- 7,266
04-17-2015, 01:35 PM #7Xtreme Member
- 7,266
04-17-2015, 08:17 PM #8LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Clogged filters aren't normally an issue with the 4L60E. It's obviously an easy place to start though. If you don't see anything obvious there, you have one of a couple options. Either the converter, pump, or input drum is broken. It's easy to diagnose a bad pump just by disconnecting a cooler line and start the vehicle. If you have no cooler flow, the pump is broke.
FrankGail C. Cahall
04-17-2015, 09:39 PM #9InActive Member
- Aug 2014
- christopher
- 1996 Camaro Z28
- 146
Thanks all for the input! I took the pan off today and there is a bunch of metal shaving. Also what's weird is there are tiny little cylinder shaped metal pieces. They look machined so I'm guessing something inside broke apart. I'll post a picture in a bit.
04-18-2015, 01:27 AM #10InActive Member
- Aug 2014
- christopher
- 1996 Camaro Z28
- 146
Alright so as you can see there is a little tiny chunk of metal and the cylinder shaped piece of metal I was talking about. It looks almost like a transmission roller clutch piece. it's so tiny. But it's too perfect to be a random piece of metal that broke off. And there was 3 of these. I have never changed the tranny fluid since I got the car so there was a decent amount of metal dust in there.
