Results 1 to 9 of 9
    Default 2015 LTX SHOOTOUT hotel info.
    FOR THOSE ATTENDING THE 2015 LTX SHOOTOUT, here are the hotel details:
    Information can also be found on the 2015 LTX Shootout site.
    http://www.ltxshootout.com/#!hotel-info/cxpz
    It should automatically enter the LTX group code, however if it does not, the code is "LTX" and lowers the price from $126 to $109 per night. I just checked to see how early the block is good for and as early as Wednesday check in, to a Sunday night check out, the group code was still valid.
    Guests may also call 270-745-0088 or
    1-800-HOLIDAY and mention block code LTX.
    Thank you,
    Lacy Campbell
    Group Rooms Coordinator
    Holiday Inn University Plaza
    1021 Wilkinson Trace
    Bowling Green KY 42103
    (P): (270)745-0088 EXT 1032
    (F): (270)745-0019
    2015 LTX Shootout Hotel information.
    Stickied
  4. The Following User Says Thank You to popo8 For This Post:
  5. #4
    Bump. Get booked!
    LTXtech.com is my Drug...
  6. #5
    Our room is BOOKED! CHECKING IN ON weds the 2nd...
  7. #6
    The FABRICATOR!
    Jul 2011
    southern illinois
    As of August 5th, if you try to reserve a room online it will say that there are no rooms available, but if you call in and ask you should be able to reserve under the reduced rate.
  8. #7
    Thank You Chris.
  9. #8
    LTXTech Sponsor
    Feb 2009
    Brad
    1979 Monte Carlo
    Moscow Mills, MO
    Blog Entries
    1
    You must use the contact information below for getting the LTXShootout discount for rooms now that the block of rooms we had set up has expired.
    Kaleighn Whipkey
    (P): (270)745-0088 ext. 1032
    (F): (270)745-0019
    Kaleighn.whipkey@jqh.com
    2013 King of Street & ES/PA Champ
    1979 Chevy Monte Carlo 383,Stock Ported Heads, 4L80 with Edge converter, QP 9", Nitrous Outlet Plate Kit
    Certified Performance & Auto Repair Inc.
  10. The Following User Says Thank You to 79LT1Monte For This Post:
  11. #9
    Bump... bump... bump. Lock in ur rooms before the hotel is full!
