Page 3 of 15 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 143
  1. #21
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    How in the hell....
  2. The Following User Says Thank You to Fastbird For This Post:
  3. #22
    Whats the runout on the crank snout?
  4. #23
    WOW... how could that even happen?
    With that being said, why are you set on forged (more cost), are you planning on a power adder?
  5. The Following User Says Thank You to popo8 For This Post:
  6. #24
    The FABRICATOR!
    Jul 2011
    southern illinois
    I wonder if the ATI balancer was honed out a little too far to begin with and that caused the chain of events. What stroke crank are you looking to replace it with?
  7. #25
    LTXTech Sponsor
    Dec 2009
    Mike
    1994 formy
    Temple Terrace, FL
    I have to double check the crank specs. I already found the forged counterpart from eagle for 600. I do eventually want to add boost somewhere between 8 and 10 lbs. I just figure since im there i might as well put in a high quality part. From what I saw and the mech said it seems like the balancer was loose and wobbling and slowly but surely got worse and worse.
    383, Eagle crank, scat rods, Mahle pistons, 238/248 .565 cam. 3k stall, AFR 210 heads, Pacesetter LT, 58 MM TB and a few other goodies.
  8. #26
    LTXTech Sponsor
    Dec 2009
    Mike
    1994 formy
    Temple Terrace, FL
    3.750 in stroke I want to stay the same as it had but forged. I may also be in the market for a LTCC set up if i can find one for a good price and an electric water pump
  9. #27
    LTXTech Sponsor
    Dec 2009
    Mike
    1994 formy
    Temple Terrace, FL
    Here is my "stand by to stand by" post. The shop is finishing up another project before the work solely on mine. Happens to be a really nice 41 ford drop top. I found the new crank and will most likely be buying it after pay day.
    http://www.summitracing.com/parts/ESP-435337505700/
  10. The Following User Says Thank You to spikester7878 For This Post:
  11. #28
    Nov 2008
    Enrique
    93 Z28
    Houston/Clear Lake
    Great to hear your not going to part it. A lot of us has gone through hard times and sat on our vehicles. I know I have for a while and I'm just getting back into it little by little.
  12. The Following 2 Users Say Thank You to 383z For This Post:
  13. #29
    Feb 2013
    Rob Milton
    1994 Formula M6
    Plover, WI
    Worst case, could you slap a used short block in?
  14. The Following 2 Users Say Thank You to MrAngry For This Post:
  15. #30
    Quote Originally Posted by spikester7878 View Post
    Have u checked with our site vendors to see if they can belp u out with that purchase?
