View Poll Results: Which would you choose?
- Voters
- 14. You may not vote on this poll
S60 rear
9 64.29% -
EFI/24x conversion
5 35.71%
Results 21 to 22 of 22
02-11-2015, 05:18 PM #21LTXTech Sponsor
- Feb 2009
- David
- 1985 Camaro Z28/1994 Firebird Formula
- MO
- 918
I would go with the EFI/24x for the reasons mentioned above. I don't think I would want to tear everything apart again to change harnesses once I had it together.
-David-
02-11-2015, 07:16 PM #22
I understand the budget approach but never settle just because anything is initially cheaper, the difference will long be forgotten but in the end you'll still have whatever you bought. Of course this isn't to say it's a bad choice, just don't let dollar amount be the only deciding factor. Turbo cars from my understanding and especially a 3 speed one, will tend to favor a taller gear. The tallest gear available for a S60 is a 3.55, maybe this or something steeper will be ideal for your combo. If that is not the case though you have no option since the S60 only has about 13 available gear choices, the 9" on the other hand has gearing as tall as 3.00 and has almost 50 available choices.
Like I stated though, I'm not a turbo guy and someone with more experience could give you better advice on what gearing will best match your comboLast edited by myltwon; 02-11-2015 at 07:19 PM.
