Results 1 to 9 of 9
    LTXTech Sponsor
    Feb 2009
    David
    MO
    Default 2015 LTx Street Stock Rules
    Street Stock
    Qualifying,Ladder, & Tree Information
    Limited to quickest 16 qualifiers. Sportsman ladder. .400 Pro tree.
    Vehicle/Body Rules
    Open to third and fourth generation F-body and factory equipped GM Y-body and B-body cars. LTx conversions in any other platform will be considered on a case by case basis. All requests must be submitted in writing with as much detail as possible prior to the event for consideration in this class.
    The body must be stock for the year, make, and model claimed. Aftermarket panels are limited to hood and trunk lid/hatch. No fender well or wheel tub modifications.
    L99 – minimum race weight 3200 lbs Automatic transmission only. LT1 – minimum race weight 3350 lbs Automatic or Manual Transmission. LT4 – minimum race weight 3450 lbs Manual Transmission Only. Minimum race weight includes driver. NHRA rules for ballast apply. Maximum of 100 lbs removable weight including weight box. Any loose ballast will result in a disqualification.
    OEM dash required. Carpet and interior panels forward of package shelf required. Must have headliner, sun visors, instrument panel, and vents. Radio and HVAC controls may be replaced with delete panel. Two front seats are required and must be securely mounted. Aftermarket seats are allowed. Rear seats may be removed. Windows must be factory style safety glass and operational. Lexan windows are prohibited. All mirrors for body style required.
    Engine & Drivetrain Rules
    Stock L99, LT1, or LT4 engines only. Engine must be internally stock using stock or stock replacement components. Factory style rebuilds allowed but must retain stock bore and stroke. Internal modifications limited to rocker arms and valve springs. LT4 engines are limited to stock rockers and valve springs. Guide plates allowed if non-self-aligning rocker arms are used. Minimum deck height of .015”. Stock thickness head gaskets required for engine block and heads claimed. OEM hydraulic lifters required. Modified or limited travel lifters are prohibited. All engine internals including, but not limited to, pistons, rods, crank, valves, camshaft, heads, and block must be stock or stock replacement (stock replacement defined as: must be the same size, material, weight, design, and construction as Original Equipment) and correct for the engine claimed. Cylinder heads must retain published stock volumes. Cylinder head modifications are limited to stock valve job. Cylinder head porting and or welding is prohibited. Bolt in solid motor mounts allowed. No motor plates.
    Stock intake manifold required. Edelbrock LT1 specific intake manifold may be used. Intake may not be modified or ported. The only exception would be modified at the front openings for larger than stock throttle body.
    Exhaust system may be replaced with tubular headers and aftermarket exhaust systems. Mufflers are required. Exhaust must exit behind driver seat area. Exhaust cut-outs may be open on vehicles with y-pipe/single exhaust but exhaust must pass through muffler first.
    Stock LT1 PCM required. Engine must have a fully functional opti-spark distributor. Stock style aftermarket opti-spark distributors allowed. Aftermarket ignition boxes allowed. Two-steps not permitted.
    Any size fuel injector and throttle body allowed. Pump Gasoline only. No race fuels allowed. All cars must use stock fuel tank. Aftermarket fuel pumps and pressure regulators permitted.
    OEM alternator must be installed and functional. Alternator may be relocated. No mini alternators or “loose belt” allowed. Battery must be of sufficient capacity to start the car at all times. Rear mounted batteries must be mounted and vented per NHRA specifications and have a functional disconnect switch.
    Any automotive rear axle permitted. Drive shaft must be steel or aluminum only. Automatic transmissions: 700R4 or 4L60e only. Modifications limited to shift kit, pan, cooler, and torque converter only. No trans brakes allowed. Manual transmission: T56 only.
    No Power adders or power adder equipment allowed on/in the vehicle.
    Chassis, Brakes, Suspension
    Front Suspension: Direct replacement aftermarket control arms permitted. Tubular K-member permitted. Stock style drag shocks/struts allowed but must mount in stock location. Sway bar may be removed.
    Rear Suspension: Direct replacement rear suspension components allowed. Stock style replacement sway bar allowed. Aftermarket torque arms permitted. Torque arms may be relocated off of the transmission. Stock style drag shocks permitted but must mount in stock location.
    Chassis: Tubular bolt in replacement K-member permitted. Sub-frame connectors permitted. OEM style steering required. Power steering may be removed or bypassed.
    Brakes must be OEM and functional. OEM brake upgrades allowed (LS1, C5, ect.). Line locks may only be used on front brakes. No aftermarket race brakes allowed. ABS may be removed.
    Wheels & Tires
    Any automotive wheels permitted. Any DOT legal rear tire that fits within the stock un-altered wheel openings permitted. Tires must not stick out past fender. Front tires must be DOT legal and minimum 4.5” tread width.
    Street Equipment
    All entries must have functional lights, horn, turn signals, and wipers minimum. Cruise control, fog lights, air conditioning, heat, and radio may be removed.
    Class Safety Requirements
    Vehicle and driver must meet NHRA certifications for time and speed the vehicle is running.
    -David-
  2. The Following 3 Users Say Thank You to DMBlack For This Post:
  3. #2
    Apr 2012
    Pasadena, MD
    A few questions:
    We can run dumps with bullet-style mufflers but cannot have a full exhaust (IE y-pipe and catback) with a cutout open?
    Is E85/98 considered "pump gas?
    Alternator relocation allowed to where the A/C compressor is?
    Does the battery box in the trunk need to be vented if it is a dry cell (optima) battery?
    Thanks!
    1993 Camaro V6->LT1 swap. LS1 Lid swap, Pacesetter Longtubes + ORY, 3" magnaflow w/ electric cutout, Full Suspension, Sparco Seats.
    12.70@104 mph Personal Best. 1.66 60'
  4. #3
    LTXTech Sponsor
    Feb 2009
    David
    MO
    Exhaust cutout may be open on y-pipe/single exhaust vehicles but must pass through a muffler (IE bullet style muffler in intermediate pipe and cutout after bullet style muffler).
    E85/98 is not allowed in Street Stock. Pump gasoline only.
    AFAIK NHRA still requires drycell batteries to be in a battery box vented to outside of the vehicle.
    -David-
  5. The Following User Says Thank You to DMBlack For This Post:
  6. #4
    yall trying to take down the champ?
    "Just another bolt on only LT1 that can kick ur LS1's a$$!"
    Special thx: Frank Cahill, Noyzee Racing, Coastal Customs, Shon Herron, John P. (1slowformula)
    Cecil - 11.998 @ 111.02mph 1.635 60ft ... 1/8th 7.588 @ 89.33mph
  7. #5
    "He"aint the champ if hes not there to defend.
  8. #6
    Nov 2010
    CHRIS
    94 CAMARO.
    Biloxi, MS
    as always guys you do a exceptional job with the rules. it never ceases to impress me how close and fast you guys run with such a restrictive rule pkg.
    http://ltxtech.com/forums/image.php?type=sigpic&userid=3572&dateline=1317253  626
  9. The Following User Says Thank You to BIG CAT For This Post:
  10. #7
    I agree. great job guys on this class. It is a boat load of fun!
    Popo dont be jelly bro its ok
  11. #8
    Apr 2012
    Pasadena, MD
    Working the bugs out of my car still, got my mph up to 110 one pass last time I was out but the car was acting funky. Gonna get her retuned and see how she does
  12. The Following 2 Users Say Thank You to Socom For This Post:
  13. #9
    ^^^ some hell of a good numbers in your sig. Sounds like a strong runner! Mine currently isnt even running!
