Results 11 to 15 of 15
Thread: Best pinion angle
10-09-2014, 10:56 PM #11
You will have some noisy ass driveline stuff if its severely off.
10-10-2014, 12:13 AM #12The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Well, from what I've READ (not much real world experience here so if im off, someone please correct me) the common -2ish preload (measured with the suspension sitting stationary under full weight with driver in seat) is a benchmark because when the car launches, the pinion rolls upward under load and (should) put the pinion to driveshaft angle at zero, where the least amount of energy is being lost due to misalignment in the u joint. This is great in a racing environment where you want to minimize driveline loss.
From a normal driving condition situation, a u joint should have at least 1° of misalignment to keep the bearings in the u joint cups from wearing improperly. It is considered "balanced" when the joints have equal but opposing angles. Meaning if your front u joint, measured in the difference between the trans yoke and top of driveshaft is +2° then the rear joint should have -2° measured between pinion yoke and top of driveshaft. This would be considered to be in perfect balance. The industry standard seems to call for no more than 3.5° for longevity with 5° becoming a reason for concern. From the factory, most gm crankshaft centerlines are between -3 and -4°. The angle of the driveshaft depends on the depends on the length of the driveshaft. If you have a shorter wheelbase and longer transmission, you're going to have a shorter driveshaft and have to pay closer attention to your angles.
http://www.hotrodhotline.com/md/html..._harmonics.php
Maybe I said that rightChris
10-10-2014, 12:21 PM #13Xtreme Member
- 7,271
Supporting Member^what he said
11-08-2014, 11:45 AM #14Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
firebird_95 well said.
01-14-2015, 08:05 PM #15
1997 Camaro Z28 (LT1/T56): K&N CAI | SLP shorty headers | UMI LCAs w/ relocation brackets | UMI adj. panhard bar | UMI adj. torque arm | Ram Powergrip clutch | Pro 5.0 shifter | skip shift eliminator kit | WS6 Store rotors | Hawk HPS pads
