Results 1 to 8 of 8
Thread: Outlaw cars....
    10 Second Club
    Josh Hamming
    1996 Camaro Z28
    Lee's Summit, MO (KC)
    Default Outlaw cars....
    How many of you guys run strictly 1/8th mile these days? I do, because the class I run in is an 1/8th mile heads up class. How about you?
    Josh Hamming
    1996 Z28
    8.503 @ 155.53 at the 2016 LTx Shootout
    1/8th mile for me. All X275 Races are 1/8th.
    Stefan D.
    1993 Trans AM TY TECH 401 CI LT-4 AFR 215RR- F1R Reverse - Edelbrock 18*- BS3
    NASTY
    Nov 2010
    CHRIS
    94 CAMARO.
    Biloxi, MS
    Ether one. Makes no difference to me. My junk has no problem making it a extra 660ft.
    http://ltxtech.com/forums/image.php?type=sigpic&userid=3572&dateline=1317253  626
    10 Second Club
    Josh Hamming
    1996 Camaro Z28
    Quote Originally Posted by Stefan D. View Post
    I figured you were all 1/8th mile. What all do you have to change to run 1/4?
    Josh Hamming
    1996 Z28
    Aug 2012
    1968 SS Camaro 396LT1
    NW AR
    Rear end gearing is the main thing.
    A car that is all set up to have a good starting line ratio and max out the rpm right at the 1/8th mile would take a lot of effort to work out a new combination that still cuts good 60fts and can make it to the 1/4 without bouncing off of the rev limiter.
    Also there isn't nearly as many races that run the 1/4 near me. I have one track that sometimes has events for the 1/4, and 3 tracks that have 1/8th mile events often.
    68 Mechanical Alcohol Injected LT1.
    10 Second Club
    Josh Hamming
    1996 Camaro Z28
    Quote Originally Posted by noice View Post
    I know the theories. I was asking Stefan specifically what HE has to change. If I wanted to run 1/4 mile, I have to change tires AND rear gear. I'm afraid these little 26x8.5's I race on won't be very stable at ~160 mph, and even if I put 275s on my car, then my 4.11 rear gear will still probably be too steep to run out the backdoor on a 1/4 mile run.
    Josh Hamming
    1996 Z28
    Nov 2010
    CHRIS
    94 CAMARO.
    Biloxi, MS
    Quote Originally Posted by Ponyhntr View Post
    Don't sweat the 26's. Greathouse has run 5.0x's on them.
    10 Second Club
    Josh Hamming
    1996 Camaro Z28
    Guys have been 4.90s on them actually, but thats still only 1/8th mile. 1/4 mile is a little different story.
    Josh Hamming
    1996 Z28
