Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    LTX Regular
    Feb 2014
    Weston Ketner
    1995 trans am
    Herndon, Pennsylvania, United States
    Default Clear birdy tail lights.
    Ok so ive had a lot of people ask me about my clear tail lights and i figured maybe someone else would like to try or be interested in em. No one ever made aftermarket tail lights for the 93-02 firebird and it sucks for those of us that want to look different. So i started ripping tail lights apart to make my own. I have a white car so clear with colored bulbs look pretty badass. Now here the bad part.... the only lights you can do this too are 93-97 LT1 lights. The honey combs on the 98-02 models are solid red plastic with the black outline made into the lens. The LT1 lights are clear lenses with the black slats and the red and clear for reverse are actually seperate lenses inside the housing.
    Now ive seen people use an oven for this set at 325° and put the lights in for 28 min. Ive never needed an oven because after 20 some years the glue isnt that strong. I use a body panel tool and pry between the 2 peices while i pop the retainer clips.
    Be very nice and take your time. Rushing here will only result in cracks or delamination. And you will be looking for another light. (Not an easy or cheap fix) Once you get it apart you will have 2 pieces.
    You can now pull out the 2 lenses. Ive seen em with the reverse lense still in but thats completly up to you. If your chrome looks beat now is a good time to repaint. I use rustoleum chrome paint. Works pretty good. Then its time to put em back together.
    After you clean all the old glue out of the seem you can use your choice of silicone to seal em back up. I used ultra black and everything looks factory around the seam.
    And this is the finished product. I ordered colored led bulbs instead of painting stock bulbs. Im still waiting on ebay for everything and once i have it all installed i will post bew pics. Hope this helps. Any questions feel free to ask.
    Ps. If your light does delaminate i have a guy that sells reverse decals for the lt1 lights. You put the decal on and spray it with nightshade and peel the decal off. And the light will look brand new and will never delaminate again.
    Sent from my SCH-I605 using Tapatalk
  2. The Following 6 Users Say Thank You to kitt8090 For This Post:
  3. #2
    Mar 2014
    Matt
    1996 Trans am WS6
    Nice write up im looking forward to the pics of the lights installed with bulbs
    96 WS6 A4, LTCC Coil Conversion, BBK 52mm, Tuned, Hooker Coated Long Tubes, TSP Stainless ORY,Gmmg,Eibach Prokit, Blisten HDs ,Panhard,Lcas, Relo Brackets,Hurst leather shifter on auto, Braided lines with Fan cooled Transmission cooler, Fuel line relocation, Torque thrust 2s. Custom interior
  4. The Following User Says Thank You to 96firebirdowner For This Post:
  5. #3
    LTXTech Sponsor
    Dec 2009
    Mike
    1994 formy
    Temple Terrace, FL
    that looks awesome. I tried to do it once....but had no idea what I was doing when I tried to take it apart haha
    383, Eagle crank, scat rods, Mahle pistons, 238/248 .565 cam. 3k stall, AFR 210 heads, Pacesetter LT, 58 MM TB and a few other goodies.
  6. The Following User Says Thank You to spikester7878 For This Post:
  7. #4
    Very nice write up man!!!
    Stickied.
    LTXtech.com is my Drug...
  8. The Following User Says Thank You to popo8 For This Post:
  9. #5
    LTX Regular
    Feb 2014
    Weston Ketner
    1995 trans am
    I have broken my fair share of lights. This isnt as easy as i showed but with a little bit of patience and time itll look great.
  10. #6
    LTX Regular
    Feb 2014
    Weston Ketner
    1995 trans am
    Update: waiting on 2 more lights but i got the right side in. uploadfromtaptalk1403910868415.jpg
  11. The Following User Says Thank You to kitt8090 For This Post:
  12. #7
    LTX Regular
    Feb 2014
    Weston Ketner
    1995 trans am
  13. #8
    LTX Regular
    Feb 2014
    Weston Ketner
    1995 trans am
  14. #9
    LTX Regular
    Feb 2014
    Weston Ketner
    1995 trans am
  15. The Following User Says Thank You to kitt8090 For This Post:
  16. #10
    Damn man... came out great. NOT diggin the blue reverse light...but its ur ride.
    Either way...good luck.
