Results 1 to 10 of 10
Thread: 93 Rear end swap???
02-20-2014, 08:22 AM #1VIP Member
- Sep 2010
- HENRY HUBBARD JR
- 93 FORMULA, 94,95 AND 96 TRANS AM'S
- KILLEEN, TX
- 141
93 Rear end swap???
Hey guys I plan on doing a rear end swap in my 93 formula, but after making a few phone calls I found out that 93 is one of the special years that I cannot have a chip burned to recalibrate the speedometer for the gear change from the stock 3.23 to a 3.42. So I was wondering, is there a certain part off of a 93 manual six speed car that is interchangeable with a 93 auto four speed can to keep my speedometer accurate after doing the rear end swap??? THX HENRY
02-20-2014, 08:33 AM #2InActive Member
- Jun 2010
- Frank AKA Biggriff
- 1994 Z28 6 speed
- Yorktown
- 670
on my last 93 I had the SLP box..which I don't believe they make anymore???
02-20-2014, 08:38 AM #3"Project Storm Trooper"
- Tony
- 93 StormTrooper Z28
- Rapid City, SD
- 4,810
@Fastbird
i think he uses a dakota didgital box for speedo calibration on his 93.
Official Member of $30k Club - Work in progress1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
1987 Iroc-Z - Stock Summer DD
02-20-2014, 09:08 AM #4
I know the with the auto trans you can replace the gears in the VSS to calibrate but not sure about the manual trans. I swapped in a 94+ t56 in my car with a higher pulse rate and used the Dakota digital speedo recalibration box to set the speedometer. This unit will work for you as well.
93 Z28 M6: Bolt-ons, Cam, Vortech S-trim w/Alky 488rwhp
02-20-2014, 09:36 AM #5
02-20-2014, 10:16 AM #6Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
I've used the Dakota digital SGI-5 three times now. Never got the SLP boxes I tried to work. I found an AWESOME installation tutorial on line when I did Steve's car in 2012 that I'll scan and post later this evening. If you need help figuring out the calibration I'll throw some initial settings up too.
Posted from my LG G2
02-20-2014, 11:51 AM #7Founding Member
- Jay
- 93 Ultra Z
- Delaware
- 3,144
I'm using the gps box from auto meter . Works good.
Sent from my DROID RAZR HD using Tapatalk
02-20-2014, 01:36 PM #8VIP Member
- Sep 2010
- HENRY HUBBARD JR
- KILLEEN, TX
- 141
How does the dakota digital unit work? does it have to be wired into the car? or is it a plug and play?
02-20-2014, 03:16 PM #9Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
You've got to wire it into the car, but it fits VERY well under the HVAC controls (use sticky tape velcro to hold it up) and the instructions I'm going to post have you tap in at C220 which works BEAUTIFULLY well.
Here's the instructions. I do have these backed up in case they ever take it down:
http://www.pcmforless.com/index.php?...ches&Itemid=56
For the calibration, use the calibration LOW chart, divide your old ratio by your new ratio IIRC. So 3.23/3.42 = .944 which on the chart is equal to inbetween .941 and .948. So start at the .941 settings, and use the fine setting to adjust on the fly until the speedo reads correct. Shouldn't take much. If you have a smart phone download a GPS Speed app and use that to calibrate. Piece of cake.
02-20-2014, 09:02 PM #10VIP Member
- Sep 2010
- HENRY HUBBARD JR
- KILLEEN, TX
- 141
Ok thanks for the great advise from everyone it should be helpful
