Results 681 to 690 of 752
Thread: Project; "BEATERBIRD"
04-24-2018, 04:42 PM #681LTx Guru
30# is just the weight of the nitrous in the bottles. Two empty bottles at 17.75# each adds another 35.5#. Plus the weight of the bracket/heaters. Gotta be at least 75# with both bottles full.
05-16-2018, 04:30 PM #682The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
Well it's been a little while since I posted I've been rather busy with the car recently... finally got axle shafts that showed up from Dutchman axles. So the rear is now in the car. Next is to measure and find out how I need to modify the drive shaft.
Sent from my SM-N950U using Tapatalk94 Formula "budget build" #thebeaterbird
05-16-2018, 04:32 PM #683The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
05-16-2018, 04:36 PM #684The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
The call was having trouble and some issues running with the Holley 650 double Pumper that the car had in it and I was advised by Holley I really needed a 750 with the camshaft specs and RPM goals so I bought this beautiful gem
Quick Fuels BRAWLER drag racing 750 cfm with mechanical secondaries.
05-16-2018, 04:40 PM #685The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
While I was getting the pictures of the carburetor on the motor I noticed the carb was rocking back and forth. And upon further inspection I noticed that a helicoil I had installed worked its way out after the back corner of the intake manifold had chipped .... this potentially could have caused a vacuum leak because the previous carburetor may have not been sitting all the way down. So I'm going to get this repaired that way I can install the new carburetor and nitrous plate.
05-18-2018, 04:06 PM #686The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Well got the intake fixed ... turned out great
05-24-2018, 11:27 PM #687The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Got the intake manifold back on and the new carb
The Following 2 Users Say Thank You to zooguy For This Post:
05-24-2018, 11:33 PM #688The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Well today I finished tightening everything up and put oil inside the differential and also installed my drag bag and got The Fill hose mounted before setting the car down back on the ground. Tomorrow I'm going to take some measurements for the drive shaft to see if that has to be adjusted.
The Following User Says Thank You to zooguy For This Post:
06-16-2018, 03:21 PM #689The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
All right tonight is the big night I'm headed to the racetrack to see if all this time and effort was worth a damn.
06-17-2018, 04:31 PM #690The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
Well there is more in it I think I was emptying the float bowls on the big end. Need a wideband to see. But get there is more in it ... maybe get fueling lined out and get the shift points dialed in better maybe .2 or .3 faster.
