Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 63
  1. #11
    Overworked/Underpaid
    Aug 2012
    Peter Alpiger
    1996 Trans Am WS6; 1994 Corvette [GS Clone]
    Carrollton, Texas
    Updated first post with *Before* pics of all the stock bulbs. All interior pics are with the dimmer switch on maximum brightness. Also threw in pics of the comparison of my HID fogs vs. fogs + lows vs. lows only vs. hi-beams. Tomorrow I plan to work on getting the red LEDs for my footwells installed. Planning to hook mine up to the dimmer switch so they come on with the rest of the dash and I can control the brightness.
  2. #12
    Aug 2012
    Peter Alpiger
    Carrollton, Texas
    Installed foot well LEDs today and pics added to first post. Quite a difference in light output between the LEDs and the stock red bulbs in the gauges.
  3. #13
    Question. How do you remove the red film on Firebirds ?
  4. #14
    Title changed for u.
    LTXtech.com is my drug.
  5. The Following User Says Thank You to popo8 For This Post:
  6. #15
    Aug 2012
    Peter Alpiger
    Carrollton, Texas
    Quote Originally Posted by New2LT View Post
    I'm not removing mine, but I've read that a Q-Tip dipped in rubbing alcohol should get the glue to release. You can find methods for that using Google.
    Thanks!
    Sent from my SAMSUNG-SGH-I337 using Xparent Red Tapatalk 2
  7. The Following User Says Thank You to Blackbird96WS6 For This Post:
  8. #16
    Can't really find anything. For the door handle switches they said to drill it out. I did that but Idk if there is a better method. I don't think that will work for the HVAC Panel and such.
  9. #17
    Aug 2012
    Peter Alpiger
    Carrollton, Texas
    Woah woah, you shouldn't have to drill anything out here. The door handle lights only require unscrewing the cover panel behind the interior handle. HVAC just unbolts and pulls out.
  10. #18
    How do you remove the red film on the door handle bezel? I know theres the screw to get it off the door. But once it's off the door, how do you get rid of the red film where the bulb goes in?
  11. #19
    Nov 2013
    David
    97 355 Green TA
    Deltona, FL
    YES! This is the thread I have been longing for! I want to do the footwells, hatch light, map lights, and probably sidemarkers maybe tails.Thanks for such detail and thoroughness!
    97 TA (Rebuilding):Stock bottom end 355, CAI, 52 TB, Ported intake and lt1 heads, 227/235 LE cam, Ultra-Pro-Mags 1.6RR's, Hooker LT's, single flowmaster, McLeod Clutch. Need a 9inch rear to handle the abuse
    FLOGROWN
  12. The Following User Says Thank You to MI6TA For This Post:
  13. #20
    Nov 2013
    David
    97 355 Green TA
    Deltona, FL
    Gotta say, those footwells are sexy! I love the idea of splicing to the dimmer switch! I've had superbrightleds saved as a bookmark for months but didn't wanna start the project "in the dark".
    FLOGROWN
  14. The Following User Says Thank You to MI6TA For This Post:
