Results 911 to 920 of 966
03-02-2022, 01:48 PM #911Xtreme Member
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
03-02-2022, 03:39 PM #912
03-03-2022, 07:22 AM #913Xtreme Member
- Mike
- Conshohocken, PA
- 1,865
03-03-2022, 07:28 AM #914Xtreme Member
- Mike
- Conshohocken, PA
- 1,865
More pics: Spectra 98 tank, internal baffling, and a new LT1 fuel hat to be gutted (I needed a new level sensor). Racetronix parts are PTFE/SS -8 feed and -6 return, their larger filter housing with replaceable element, AN/ORB/QD fittings, and bulkhead harness.20220302_201727.jpg20220302_201657.jpg20220302_201038.jpg20220302_200627.jpg
Sent from my SM-A526U1 using Tapatalk96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
The Following 3 Users Say Thank You to Catmaigne For This Post:
03-03-2022, 06:08 PM #915
How much was the tank and where'd ya source it?
03-04-2022, 09:57 AM #916Xtreme Member
- Mike
- Conshohocken, PA
- 1,865
I got it through Rockauto, it was about $300 shipped after discount. Spectra GM27114C. Going to find out if this LT1 pump assy fits later today. The 98 and 97-earlier brackets look the same in the stock photos as far as I can tell.
Hopefully this fits w/o issue:
20220304_105733.jpgLast edited by Catmaigne; 03-04-2022 at 09:59 AM.
The Following 2 Users Say Thank You to Catmaigne For This Post:
03-05-2022, 12:30 AM #917Xtreme Member
- Mike
- Conshohocken, PA
- 1,865
Finished gutting this thing for now. Got to inhale a bunch of fiberglass, pretty neat.
Need to make a heat shield for the coils or maybe wrap the last primary. Other option is putting the coils where the battery is, but I dunno if I want to go down that rabbit hole.
Also debating how I'm going to secure this plate from the engine bay side. The welded nuts on the firewall complicate things. Option 1 is to grind them flat along with the inner lip and drill extra holes nearby to hold the plate. Option 2 is to design a 3D printed spacer (made of several puzzle pieces) to clear the nuts/lip and get it printed with fiber reinforced nylon. Also, I'll die before I pull the dash so don't ask why I'm doing everything the hard way.
Capture.PNG96Z M6, ERE-383 #60, AFR 210s, LE cam, 9", Procharger D1, ???whp
03-05-2022, 06:42 AM #918
What about nutserts and a washer for spacing past the lip, then goop it to all hell with RTV. Then just bolt panel to the nutserts
03-05-2022, 06:54 AM #919Xtreme Member
- 7,266
Supporting Membergood progress
Sent from my SM-N975U using Tapatalk2021 Charger Scat 392
03-07-2022, 07:52 AM #920Xtreme Member
- Nov 2008
- PA, USA
- 2,438
We have the same hvac delete panel, hopefully it fits haha. Mine is still in the wrapper with the dash hanging. One of these days I'll get to it.
