Results 1 to 10 of 13
Thread: Which way to go with my 91 RS?
12-25-2013, 02:50 PM #1Lurker
- Mar 2010
- Sean Foster
- 1995 Trans Am
- Barboursville WV
- 310
I've got my first Hot Rod I bought and built. It's what got me started on the LT1 path. I put a T56 and a 12 bolt in it with the stock 305 with a cam and headers and a 150 shot that got me to 7.88 1/8 mile. Before I bought the 95 Ta my I picked up a 93 LT1 which ultimately lead to me getting the Trans Am. Instead of boarding you guys with the last 15 years of my life I'm back to tinkering on the Third Gen.
My dilemma now is weather to put a 5.3 (which I have) or throw together a mild LT1?
heres the part that has me on the fence. The camaro currently has a LT1 T56 with steel shifter fork and carbon syncros and a MGW shifter, stage 2 spec clutch with an aluminum flywheel.
If I go with the 5.3 I would have to sale my current T56 set for a LS based set up. Or buy the conversion kit $400+ clutch and hydraulics etc.
Then I'd have to mate the Ls harness with the camaro's harness get headers etc.
then I'd need a fuel system that could run the fuel inj and N20.
OR if I go LT1 route I have a few options there.
1. Get a ready to assemble 6" rod decent pistons stock crank mildly ported heads carbed intake and basically use everything off the TBI motor (ign,fuel pump) add a carb and reuse the shorty headers (I know they aren't D port) and should be very minimal cost in this route.
2. Run the LT1 fuel inj with a 4x timing trigger and use a distributed in the rear (no opti) mating a LT1 harness to the camaro's and mess with the fuel system.
Keep in mind my goals for this car are pure street. Little bit of track action little bit of autox and a hole lot of street duty. No cage. Anyway I go it will have a 150 shot on it.
300-350 RWHP NA is my power goal. The car makes 202 RWHP now lol but it's a blast to drive and it's to nice to not get it out.
Sean Foster
12-25-2013, 07:28 PM #2VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
Lt1 hands down, would be an easier and cheaper route... ls swaps are to common are you end up being like the other 2 million people with a 5.3/6.0 swap... I would do a stock crank, decent rods pistons.. good custom grind cam with a single plane and carb
12-25-2013, 07:38 PM #3
twin turbo'ed 427 LSX!!!
1995 Firehawk #584 of 671
385cu.in LT1, Intercooled turbo
12-25-2013, 07:49 PM #4"The Rock"
Im a bit biased... ANd altho there is great potential with the lq set ups... I say stay LTX!
LTXtech.com is my drug.
12-25-2013, 07:53 PM #5"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
for your goals, I would say go LT1. It will drop right in where your 305 is now and is perfectly capable of achieving your goal in stock form with a decent cam.
12-25-2013, 08:35 PM #6
383 LTX!!! with 24x or 58x ignition system!!!.... and twin turbos!!
12-25-2013, 09:05 PM #7Lurker
- Mar 2010
- Sean Foster
- 1995 Trans Am
- Barboursville WV
- 310
Turbo(s)? Who said anything about turbo(s) lol. Defiantly on the wish list but not going to happen for years.
Sean Foster
12-15-2015, 08:10 PM #8Lurker
- Mar 2010
- Sean Foster
- 1995 Trans Am
- Barboursville WV
- 310
Update: I ended up going with a 5.3/T56 I sold my T56 setup and picked up a LS based unit. Twin 55's keeping the AC and looking for 600rwhp
Sean Foster
The Following User Says Thank You to 1sickta For This Post:
12-16-2015, 07:36 AM #9VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
Sweet! Glad to see you are still around!
Btw hows the ta doing ?
12-27-2015, 04:02 PM #10Lurker
- Mar 2010
- Sean Foster
- 1995 Trans Am
- Barboursville WV
- 310
The TA is still doing well. I actually pulled it out of the garage and gave her a bath today. 75* in December I'll take that.
Sean Foster
