Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
  1. #31
    duhhhh. ... I just realized, in the picture the torque arm has been removed. That's why the pinion shaft rotated upward and moved the driveshaft upwards. Or was it like that BEFORE you removed the torque arm?
  2. The Following User Says Thank You to Injuneer For This Post:
  3. #32
    Shit i just noticed that now that you said something lol @383z
    2021 Durango R/T Tow-n-Go
    1994 Firebird Formula 381 stroker - Carrying the torch! - 10.84 @ 123mph on a 150 shot RIIIIICH
  4. #33
    Would be interested in seeing how this one worked out.
  5. #34
    Mar 2013
    94 Z28
    is everything
    ditto, alignment issues without the torque arm installed is not surprising...
  6. #35
    Nov 2008
    Enrique
    93 Z28
    Houston/Clear Lake
    Ok, that make a lot of sense and I did know that. Thanks everyone! I was going to start cutting up the safety to make it work. I'm so glad I didn't.
  7. #36
    My umi is doing the same exact thing... I ended up lowering my trans cross member with some spacers.... Maybe it's a UMI defect?
  8. #37
    Quote Originally Posted by 1fstss View Post
    Were you seeing the DS up close to the top of the DS loop, WITHOUT the torque torque arm in place? That would appear to be the cause of what should turn out to be a non-problem for the original poster (383z).
  9. #38
    Yes even with the torque arm not on the axel it was still rubbing. All I did was space my bmr trans mount x member and lower the tail shaft slightly. It gave me like 3/4 inch clearance.
  10. #39
    Without the torque arm is EXACTLY when it would be most likely to rub.
    Do you have the BMR trans mount cross-member because you did a transmission conversion? That might have contributed in the change in trans height, as will the choice of transmission mount. I don't think this is a typical problem with the BMR component.
  11. #40
    Yep put in a th350 and it was rubbing with the torque arm on and off. In order to get it to clear without moving the x member my pinion angle was way off... The th350 has a solid mount, I was gonna put in a poly mount off my old x member but it was taller and would push the tail shaft shaft further up.
