Results 1 to 10 of 18
Thread: Opti causing miss?
09-01-2013, 08:22 PM #1
Opti causing miss?
I have a miss at high rpms (starts around 5,000). I changed the plugs and wires today thinking it would fix it but no such luck. Is my opti going bad? It has had this miss for the almost 3 years that i've owned the car but I never really thought any thing about it. The car has 135k miles. Has anybody experienced this or have any suggestions?
09-01-2013, 10:15 PM #2Lurker
- Dec 2012
- Tommy N.
- Silver 1996 Camaro Z28, Green 1996 Camaro Z28
- El Paso, TX
- 946
I heard optis start to cause a miss at higher rpms is a sign of it starting to go bad but I'm not to sure I'm still learning about these motors
1996 Camaro Z28 pacesetter lts and ory Texas speed performance Catback exhaust K and N cai. 14.1 1/4 mile96 Camaro Z28 Silver Mostly Stock, Full Exhaust
09-01-2013, 10:53 PM #3The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
High rpm miss can be caused by many things, opti being one of the more common culprits. Before spending any money though, do you have any means of diagnostics or data logging in order to narrow down the list?
09-02-2013, 12:28 AM #4"The Rock"
I used to have a high rpm mis. my opti was blamed...swapped in what felt like a million optis....after years of fightin...ended up being tune related.
MEMBER @ LTXtech.com
09-02-2013, 01:54 PM #5
09-02-2013, 02:03 PM #6"The Rock"
The problem was that out of all of the local tuners and thousands of dollars...none of them were ltx competent.
Great people...but apparently...the ltx ia a dif animal.
Bryan Herter of pcm for less was the surrogate tuner through a semi local shop that he had previous hands on training with..and he made it RIGHT.
My build is a bit IN DEPTH and that complicates it as well...but as for details...idk
09-02-2013, 05:38 PM #7
The guy that tuned my car is a local guy and seemed to know what he was talking about. But maybe I should check around and see if someone else has a little better info. Thanks! ill post back when I get some opinions
09-02-2013, 05:57 PM #8Xtreme Member
- 7,270
Supporting MemberOpti causing miss?
Change ya plugs first, put copper cores in. I had a high rpm miss for months and went threw 2 sets of iridiums and one set of platinums until i said eff this listened to either injuneer or ramair95ta and used autolite coppers, poof miss was gone. I had a miss with stock and tuned ecu's
09-03-2013, 08:12 PM #9
The car seems to be running stronger after putting plugs and wires in it but still has that high rpm miss. I'm not hot rodding it all the time where it really or drag racing where is really matters. But I would like to figure it out because I want everything working perfectly, like most of us on here...
09-03-2013, 08:15 PM #10"The Rock"
Whats ur plug gap?
