Results 61 to 70 of 83
11-29-2019, 07:08 AM #61Xtreme Member
- 7,268
03-17-2020, 05:09 PM #62
Need help
Help please!!! I have a 1996 Camaro RS and my 4l60e is done for. I have a good 4l60e out of a 1998 Firebird (also a v6 car). Can I put the 98 into my 96?
03-20-2020, 09:49 AM #63Xtreme Member
- 7,268
07-13-2020, 08:14 PM #64
I have read through all the posts in this thread and hope someone in the know can answer a question....here is the story....bear with me please .... in the early 2000's, I bought a 63 nova hardtop....being one not to leave well enough alone, it was time for out with the old straight 6 and glide and in with something else - a LT1 with a 4l60e out of 96 corvette with only 50k on the odometer.....things progressed and I put the 4l60E on the shelf in favor of a t56.....am still sorting out rear suspension and other things but that combo seems fine.....enter a new project...65 El camino .....nice straight rust free car but a tired 327 with a turbo 350.....time for a LS in the 65 ....here is what I have and need to know.....I have a 5.3 L59 out of 2002 tahoe...no trans with it but it was a truck 4l60e .....I'm going to redo the harness to get rid of the unneeded circuits of a LS swap in an older vehicle and may go with a 03 drive by wire instead the drive cable intake that came with the 02.....have the intake with tac module ...pcm and harness.....anyway, will the 96 corvette 4l60E work with the 5.3? Appreciate any info to make a decision on....thanks in advance
07-13-2020, 08:22 PM #65LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
No, the '96 Trans will not work with the 5.3.
The 5.3 needs a 2000+ 4L60E.
Sent from my LM-V600 using TapatalkGail C. Cahall
07-13-2020, 08:55 PM #66
Thanks.....that saves me a lot of headaches...know what to look for now
The Following User Says Thank You to T37 For This Post:
07-13-2020, 08:56 PM #67LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
You're very welcome.
The Following User Says Thank You to CPT For This Post:
10-26-2020, 11:09 AM #68
This thread just keeps on going, I love it.
I am contemplating a similar combo, I have found a 2001 6.0L LQ4 that had a 4L80E, and I have found a '97 4L60E from a 5.7 Vortec truck. If I find the correct crank spacer and flex plate, will this work with the '01 PCM (I have the ability to tune the PCM if need be)? If not, what are the issues and what would I need to make the combo work? I'm an electronics tech/mechanic so tuning, harnesses, solenoid swaps etc are not a problem for me.
Tranny code 617CJDY
TC code DHHF
Please and thanks.
CheersLast edited by kilohertz; 10-26-2020 at 11:44 AM.
12-03-2020, 05:43 PM #69
Will a 2002 4l60e work in a 1996 Tahoe?
04-28-2021, 12:38 PM #70LTX Member
- Apr 2021
- Arturo
- 94 k1500 choo choo conversion pickup
- 2
Newby, trying to get my 95 k1500 5.7l back on the road. Bought truck without transmission. Found a 97 one piece PWM trans. I did not know that 95 was year specific only. After reading thread 100 times or more I am confused about the PWM trans that originally came in truck. Why won't the 97 PWM pump and valve body work in my 95???? Don't want to put it in if it won't work... I have already purchased overhaul kit converter for the 97... Built it with new pump and valve body... So according to the facts I have to use a 95 pump, valve body, spacer plate and internal harness for the 97 to work? Right? What about the converter??? Will the 97 I ordered work with all the 95 stuff?? A little dazed and confused on this issue .. need to have it running ASAP BUT WILL WAIT FOR CLARIFICATION ON MY ISSUE... I APPRECIATE ANY AND ALL HELP AND PROMISE TO NOT PARTAKE IN BUYING ANOTHER VEHICLE THAT IS MISSING THE ORIGINAL TRANSMISSION... EVER EVER EVER,😫😫😫😫😫😫
