Results 41 to 50 of 83
03-17-2015, 09:21 AM #41LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Gail C. Cahall
03-17-2015, 08:04 PM #42
03-17-2015, 09:57 PM #43LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Gail C. Cahall
03-18-2015, 05:46 PM #44
I have a 2001 5.3L suburban engine that obviously came with the 4L60E 4x4. I am looking for a 4x2 4L60E, what are all the years should I be looking at getting for that 2001 5.3L to allow the wiring harness to merry up with out issues. Thanks in advance.
03-18-2015, 06:26 PM #45LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Gail C. Cahall
03-19-2015, 07:24 AM #46
What exactly is stopping me from using that transmission instead of trying to locate a 4x2 one? I don't have a drive shaft for my 64 C10 created yet, so is it purely the drive shaft yoke that wont work because of spline count or whatnot?
03-27-2015, 09:04 PM #47
I see in the original post that at least twice, it lists 4L60E for 93 models. I'm curious as to why. is there a mid model year switch to the '60E? I was under the impression that 93's came with 700r4/4L60. Could someone chime in as to what 700r4/4L60's are compatible? Maybe what mods are required for the different models? Truck tranny swaps, etc. I started a thread about using a 700 from a 2wd truck (88-92 modles) in my 93 but it looks like maybe this thread would be best for other 700r4 guys.
*edit* my mistake,it clearly says that 4L60E was only available in trucks for 93. Sorry. My fail. But, my question still stands about using a 700 from a truck in a 93 fbody.Last edited by bigvanvader80; 03-27-2015 at 09:08 PM.
03-28-2015, 11:13 AM #48LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
The '93 F-Body used a 4L60 (not a 700R4). While the 2 are operationally the same, they aren't directly interchangeable. The '93 4L60 uses a round, 5 pin case connector. the 700R4 uses a square, 4 pin case connector. The reason for the different connector is the 4L60s unique pressure switch arrangement on the valve body that control converter clutch apply. The valve body holds 3 pressure switches on a '93 unit. The later 700R4s only had a provision for 1 switch. The '93 4L60 also had changes made for reverse apply. This made in necessary to design a "one off" valve body casting that had a 3rd check ball, whereas the 700R4 only had 2. The extra check ball required a separator plate with a coinciding hole. What many rebuilders even overlook is the fact that a '93 4L60 uses a 4L60E pump stator and reverse input housing. If any of these parts are mismatched, it can cause either a harsh or soft reverse engagement. If the electronics for the pressure switches/converter clutch aren't correct, it won't have converter clutch (lock up) apply. This will cause overheating and subsequent 3-4 clutch failure in the transmission.
Gail C. Cahall
03-29-2015, 08:02 PM #4993 Z28 - LT1/built bottom end/PP and milled heads/CC .495/.501lift/LT's full 3.5" exhaust/3.73 rear with Auburn posi - Daddys toy/driver
04 Tahoe Z71 5.3 - Mommy's DD
05 Denali 6.0 AWD/Diablo Trinity - Daddys DD
04-21-2015, 09:13 AM #50
Awesome thread, Frank I thank you for all the information you have supplied. I have a question that has been partially answered in this thread but I need clarification for a 93. I am picking up a 93 truck with a bad 4l60e in it, I have a good 97 4l60e from a LT1 camaro. can I change the wiring valve body and separator plate from the 93 to the 97 and install the 97 trans in the 93 truck. I know this was answered for a 95 but need clarification for the 93. thanks in advance.
