Results 1 to 9 of 9
Thread: accel dfi users please help
05-19-2013, 07:22 PM #1The FABRICATOR!
- Jul 2011
- 1985 Monte Carlo SS
- southern illinois
- 7,164
I'm putting this in every forum I can trying to get some insight.
I've tried everything available to me. In the dfi PNP calibrations I've tried the sc 383 lt1 and sc 350 files. I've also tried the 2 bar preset and the be calculator. I have a lm1 wideband with a new wideband sensor in thats wired indo the dfi as a generic input (0=10-5=20) Whats happening now is after it goes into closed loop and starts leaning it out (around 13:1) it starts backfiring through exhaust. I thought the timing might be too retarded so I raised it and it helped a little but no major change. I also tried locking it into forced timing mode to eliminate any changes the dfi was trying to make. I do have a balancer with timing marks on it however theres no pointer on the cover. I've also tried the crank offset at zero and ten degrees. At this point if a basic file will not even get it to idle or run at low speeds im going to have to look into mechanical issues. I have a 2 bar map sensor in. Build is a 355 95 lt1 with optispark, 223/234 cam, 60# smartfire injectors, m122 supercharger, Any suggestions?Chris
05-19-2013, 07:27 PM #2"Project Storm Trooper"
- Tony
- 93 StormTrooper Z28
- Rapid City, SD
- 4,810
@JPack
Sent from my DROID RAZR using Tapatalk 2
Official Member of $30k Club - Work in progress1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
1987 Iroc-Z - Stock Summer DD
05-19-2013, 07:30 PM #3The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
Lol that's actually the email I sent him. He's all over it. I was just throwing this out there if anyone else had something to add.
Plus I feel bad blowing him up all the time.Chris
05-19-2013, 08:40 PM #4InActive Member
- Oct 2008
- Jim
- 1996 Z28
- Sugar Grove IL
- 1,243
Emailed preloaded setup from mine. Make sure to enter all data about the set up in config drop down. I dont know what you see not having the pro key like I have. Go to config, system, ign type drop down lt1, also enter cyl, displ, inject flow rate, fuel pressure set your tps voltage click change set low then open all the way and set high, send all to ecm. Then config, controls, ign cut off, fuel cut off, restor speed, then wideband type, if generic set it up based on linear volts and make sure it matches what you have. Config, fuel, creat base map, enter all fields... if you dont know runner length etc, google it..its all out there. Cam spec etc bore stroke. Go from there and let me know.
1996 camaro Z28, Clayton racing 398, Rossler TH350 rmvb with brake, FTI billet race converter 4400, Dana S60 with 4.10's, 300 shot, Accel DFI controlled, UMI, Spohn, PA racing, QA1's, Baer brakes, 325/45/17 M&H, Caged, Corbeau's, Simpson, etc.
From zero to fuck yeah in 3 seconds.
05-19-2013, 08:43 PM #5The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
Thanks jim I appreciate all your help!
05-19-2013, 10:05 PM #6Xtreme Member
- Dec 2011
- JeremY
- 1972 NovA
- Elsberry, MO
- 4,416
05-19-2013, 10:09 PM #7The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
05-19-2013, 10:12 PM #8Xtreme Member
- Dec 2011
- JeremY
- 1972 NovA
- Elsberry, MO
- 4,416
05-19-2013, 10:14 PM #9The FABRICATOR!
- Jul 2011
- southern illinois
- 7,164
I was going to wait till its done. But now that you mention it it might help for these types of threads.
