Page 1 of 2 12 LastLast
Results 1 to 10 of 15
    Dec 2008
    Byhalia, Ms
    Default 67 Camaro with LT1 build thread
    Well, here she is. I`ll post up details about the car later and add more pics as I go along. Hopefully it won`t take me as long to finish this car as it has taken me to get it to this stage now.
    This is a 67 RS/SS 350 camaro. I drove this car for a year before I tore it down for a refresh. It looked good from 10 feet away, but had lots of problems. The trunk floor was rotten, the floor pans were rotten, dash was rotten, outer rear wheel houses and quarters were rotten and the panel between the rear window and trunk lid was rotten as well. I have replaced all those pieces. The outer wheelhouses and quarters are NOS pieces. I gave the front cap and doors to a local to restore for me and got royally screwed. I got all those parts back except my front inner fenders and my SS hood, which were original GM pieces and in very good shape and completely restored front seats. Sucks big time, but oh well. Advice there, don`t ever trust anyone! Cool factory options that were still on the car when I bought it:
    12 bolt rearend with factory Eaton posi unit and GM 3.73 gears. I put new Moser axles, solid pinion spacer, Moser yoke, Jegs aluminum diff cover and all new Timken bearings and seals.
    Fold down back seat, needs to be restored still. Factory console with gauges and in dash tach. I`m going with aftermarket gauges and building a custom console that resembles the factory setup.
    It also came with deluxe interior. I`m going to go with aftermarket front buckets but have them recovered keeping the original factory look.
    I originally did not want to put a fuel injected motor in the car due to complexity of the install. I wanted to keep the car simple, but when you work on a car this long, it seems to take on a world of it`s own. I had an 01 ws6 that I recently sold and took a partial trade getting a 97 camaro. It had a completly built LT1 in it that had never been fired and a 4L60E trans that was needing to be rebuilt. The trans is being rebuilt right now with a lot of goodies in it. The motor has a completely forged bottom end in it, but it`s a 355. I didn`t understand why they spent all that money and didn`t go 383, but oh well. Anyway, it has some build issues. The rotating assembly was never balanced, so that has to be done. It`s a 2 bolt block with the original main bolts on it. The cam was WAY too big to run on street and get any vaccuum out of the motor for brakes or FUEL INJECTION. I dropped off the cam yesterday to have it reground so it will be streetable. It has 561 heads on it that have a very nice port job done to them, but the original valves. The CC`ers weren`t smoothed and polished either. I`m going to have the CC`ers smoothed and I have some titanium valve retainers laying around that I`m going to throw on the heads. I`m on the fence about putting new valves in. Need to keep the cost down everywhere I can. Would it really be worth increasing the size of the valves? I`m also on the fence about having the block machined to install splayed main caps or to just put ARP studs on there and call it a day. I`m also going to get a Moroso oil pan for it. It has 30# Accel injectors and a 52mm BBK TB on it as well. And came with CompCam 1.6 full roller rockers, but factory rocker studs. I bought a new MSD distributor and and a CSR electric waterpump as well. Trying to find some ARP SS bolts for the timing cover, water pump, distributor, throttle body and a few other parts. I`m going to buy an accessory drive kit from Street and Performance. I bought some polished smooth short valve covers, but am not sure they are going to work with the roller rockers. I really hate tall valve covers.
    The suspension on the car is all new Hotchkis lowering springs with poly bushings. I`m thinking of replacing the bushings with some Delrin bushings and getting tubular front control arms for the front.
    I have been doing body work on the car and it`s just a hair past the point of what you see in the pics now. The dark gray primer on the car is epoxy. I will be spraying the light gray, sanding primer over the epoxy within a few days and start doing the mock up, fitting everything. I am using a reproduction stock tank and installing a surge tank somewhere. It will be a custom fuel system with all -an fittings and black nylon hose as well as using SS hard fuel line. The brakes are 4 wheel discs. I have restored GM 15x7 ralley wheels with all new BFG rubber on the car now, but will be replacing those for some 17 or 18" billet ralley wheels. I want to keep the car looking original but with a retro twist to it. Oh yeah, I ordered a new item that is really sick. It`s a paddle shifter!
    1997 Camaro SS
    Overland Park, Kansas
    Can't wait to see the progress
    -Eric
    2004 Silverado
    Z71 - Airraid, Corvette Servo, 33" AT's, leveled, etc.
    Joliet, IL
    I saw a '69 at this years Good Guys show with an LTx swap and it looked awesome with all the chrome trim they had on it.
    Good luck & post pics as you go.
    Smoke yo lights? Pm mah
    SFV
    Damn tahts gunna be sweet when its finished, ive always wanted a old school camaro
    TEAM MIKE #666
    Bow tie for Life
    95 z28,ttops
    03 silverado
    NY
    Nice!!!
    Cant wait to see some more pics!!
    2008 Corvette Z06 | 2002 Corvette Z06 | 2002 NHRA Formula
    Founding Member
    Joplin, MO
    Awesome swap! I've got a friend in Stillwater that did an LT1/T56 swap on his 67. I don't think you'll be disappointed!
    1997 Camaro Z28
    Lots of visual horsepower, full bolt-ons, and a little spray....
    Quote Originally Posted by quik95lt1 View Post
    yea so back to the tune..........do what i said before you make yourself a paperweight lol
    Dec 2008
    Byhalia, Ms
    Thanks everyone. I drove this car for a year before I tore it down to restore it. It has taken me a very long time to get it to the stage you see now. Working full time, money and life always gets in the way of progress on it. I posted some details on the car in the original post
    i might be blind...but i dont see pics
  9. #9
    Take a look at Popular Hotrodding. On the shelves now. My buddy Sean Gustin's 67 Camaro is featured in it. Has a LT1 and 6-speed. Beautiful car! I dyno tuned it last week.
    8.453 @ 163.58 mph (best mph 164.27)
    http://ltxtech.com/forums/image.php?type=sigpic&userid=24&dateline=128017345  3
    MAY 2011 cover/feature GMHTP......Jan 2008 cover/feature Camaro Performers
    2009,2010,2011,2015 LTX SHOOTOUT OUTLAW CHAMPION
    Current LT1 N2O record holder (Sept 5 2015)
  10. #10
    LT1 > LS1
    Jan 2009
    Buffalo
    Ahhh, I'm blinded!
    That looks awesome!
    -Tom
    '94 Firebird .M6. .Pacesetter-LTs.
    Some would say.. Full-Bolt-On status
