Page 49 of 52 FirstFirst ... 394546474849505152 LastLast
Results 481 to 490 of 516
  1. #481
    Sep 2012
    Chris P. Bacon
    1994 Firebird Formula
    Lansing MI
    Thank you!
    '94 Formula 6spd
  2. #482
    Sep 2012
    Chris P. Bacon
    Lansing MI
    IT'S ALIVE!!!
    Got the Quick performance 9" rear end and BP Automotive wiring harness in. Also had the heads milled a little to help with the power loss from the rear end. Also threw in the SJM ABS delete and line lock too. The numbers aren't too impressive but going to 4.11 gears should make it feel like a different car. Picked it up last week, is it spring yet?
    '94 Formula 6spd
  3. The Following User Says Thank You to Formula218 For This Post:
  4. #483
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Some pics from local car events this spring. So nice to have this POS back on the road. Should have a new nitrous bottle in the next week and be ready to spray it.
    '94 Formula 6spd
  5. The Following 3 Users Say Thank You to Formula218 For This Post:
  6. #484
    LTX Regular
    Nov 2011
    Marc
    1995 Formula
    magnolia, DE
    Happy to see you still have "the license plate"
    Sent from my SM-A015V using Tapatalk
    1995 FORMULA M6
  7. The Following 2 Users Say Thank You to 95 blackbird For This Post:
  8. #485
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Finally got my nitrous working and put 2 step on last weekend. Hoping to get to the track soon for some times.
    '94 Formula 6spd
  9. The Following User Says Thank You to Formula218 For This Post:
  10. #486
    Dec 2011
    Louisiana
    Sounds good, looks good and making good WHP. Good job.
    '57 Chevy 3100 p/u LT1/T56
    Wife's '94 Z28 has been sold.
  11. The Following 2 Users Say Thank You to JOATMON For This Post:
  12. #487
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Went to the track Friday night to make some passes not that we got the nitrous working. I was only able to get two passes in so I still have a lot to learn with seat time and tweaking things. To refresh memories it's a cam only LM7 with a 100 shot, T56, and a 9" with 4.11 gears.
    First pass we had the 2 step set at 3500 RPMs and no nitrous, tires at 15psi. (not sure why it is rotating the pics, they are not sideways on my comp lol.)
    Second run we knew would be our last so we just threw the bottle in and got back in line. It bogged pretty bad the first pass so we bumped the 2 step to 4000 and had nitrous coming on at 4200. It still bogged a little so we definitely have more work to do figuring out the launch on DRs.
    Here are a couple videos of the pass with the 100 shot.
    '94 Formula 6spd
  13. The Following 2 Users Say Thank You to Formula218 For This Post:
  14. #488
    LTX Regular
    Sep 2015
    Brandon++S
    1997 camaro z28
    Alabama
    How did you do your 2 step with the t56?
  15. #489
    Quote Originally Posted by Brandon++S View Post
    he has an ls so it would be a little different. just have to tap it into icm signal depending on what you run. i ran a ltcc so it was integrated. also newer msd boxes are olug and play with a 2 step, you'll just have to wire in an arming switch
  16. #490
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Correct. I have the MSD 8733 2-step so just had to wire the arming switch. For that we put it on my cruise control button so i press the button at the end of the stalk and rev, then let go as I drop the clutch.
    '94 Formula 6spd
  17. The Following 2 Users Say Thank You to Formula218 For This Post:
