Page 48 of 52 FirstFirst ... 38444546474849505152 LastLast
Results 471 to 480 of 516
  1. #471
    Nov 2008
    1994 Trans Am
    PA, USA
    That is a bummer. What harness are you using now for the swap? Just a 99-02 harness?
  2. #472
    Sep 2012
    Chris P. Bacon
    1994 Firebird Formula
    Lansing MI
    A truck harness that was modified by a friend to work with the swap and keep the '94 cluster.
    Prior to this my tach has been acting up (bounces randomly, video below), while trying to figure that out I was told to check grounds. I only had one (from the block, splitting to the battery and the chassis)after doing the swap and it was fine for a couple years before the issue started. I pulled that one off and cleaned everything up, and also added two more from the alt bracket to the chassis, and the pass head to the chassis.
    After adding the one from the pass head to chassis is when the car started doing the things mentioned in the post from earlier today. I don't know if the ground caused something else to freak out, or if it's coincidence that it happened the next time I drove it. It's got a full tank of new gas too.
    Idle bounce issue i'm also having. when driving it shoots all the way from zero to the top of the gauge.
    '94 Formula 6spd
  3. #473
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Back from the dead! After fighting with the same running issue all last summer I gave up and shipped it off to my friend's shop. He's going to hopefully figure that out and then knock out the pile of parts I've built up since last winter. I couldn't handle another summer driving the DD lol.
    Quick performance F9 with truetrac and 4:11 gears, line lock with ABS delete, BP Automotive swap harness, MWC torque arm and adjustable panhard bar, and Spohn adjustable LCAs all going on. Also got some 15" wheels for the back and some 275 drag radials for fun cruising. I'll hopefully have some more updates over the next couple weeks as he has time to dive into it.
    '94 Formula 6spd
  4. The Following 2 Users Say Thank You to Formula218 For This Post:
  5. #474
    Sep 2012
    Chris P. Bacon
    Lansing MI
    '94 Formula 6spd
  6. #475
    Oh boy, did u break it?
    LTXtech.com is my drug...
  7. #476
    Sep 2012
    Chris P. Bacon
    Lansing MI
    nope, just preventative. Didn't want to have to worry about it with a sticky tire. I have some 15s and 275 drag radials for it this year.
    '94 Formula 6spd
  8. #477
    Gotcha... so u added a girdle diff cover to the 10 bolt?
  9. #478
    Sep 2012
    Chris P. Bacon
    Lansing MI
    Yeah, I put it on a couple years ago. I got it free, figured it couldn't hurt.
    '94 Formula 6spd
  10. The Following User Says Thank You to Formula218 For This Post:
  11. #479
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    moore, ok (south okc)
    Cant beat free
  12. #480
    Jul 2019
    Adrian Rodriguez
    95 trans am
    She is a Beauty,
