Results 461 to 470 of 516
Thread: '94 firebird formula
11-05-2017, 09:14 AM #461Xtreme Member
- Sep 2012
- Chris P. Bacon
- 1994 Firebird Formula
- Lansing MI
- 1,467
First part for this winters project has been acquired
'94 Formula 6spd
11-24-2017, 12:35 PM #462Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
Grabbed a driveshaft off FB Marketplace too, 3 aluminum. Previously went 9.90s so it should be plenty for my 13s lol
Quick Performance F9 has been ordered with a Yukon center, cant wait to have 4.10s instead of 2.73s lol
'94 Formula 6spd
12-05-2017, 07:11 AM #463Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
Early Christmas for the bird!
'94 Formula 6spd
12-05-2017, 12:17 PM #464Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Nice!
12-05-2017, 07:18 PM #465The Nitrous Outlet Junkie
- Apr 2010
- Troy
- moore, ok (south okc)
- 3,274
12-06-2017, 06:40 AM #466Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
$1950 with the 10% off for their black friday deal. With the 3" driveshaft and Trutrac i've got $2600 into the 9" swap. Ive tried to find a list of all parts needed but I haven't found a definitive list of everything needed. This is what I bought http://www.quickperformance.com/QP-G...xles_p_55.html . The only special options i got was the fabricated big web, and lightened axle flanges. Here is by order:
I think it should work with my founders LCAs. I have a feeling I might need to get an adjustable panhard bar it center it. My 10-bolt sat perfect with my drop so the one I have now is a Founders non adjustable. They say it will work with a stock torque arm but i might grab a tubular before spring anyway. Anyone see anything that I will probably need to get before the install.
'94 Formula 6spd
12-06-2017, 04:49 PM #467"The Rock"
Spool? Are u done doing autocross stuff, or am i thinkin of someone else?
12-07-2017, 01:03 PM #468Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
Spool was free with the rear end kit and will be sold, I have the trutrac pictured on the last page that will be swapped in. I got the Eaton for $400 so it didn't make much sense to pay Quick $750 for one too.
'94 Formula 6spd
12-08-2017, 04:57 AM #469Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
But also yes, I probably am done with auto-X for the most part. I just don't find it as fun as drag/street racing.
'94 Formula 6spd
The Following User Says Thank You to Formula218 For This Post:
08-27-2018, 07:18 AM #470Xtreme Member
- Sep 2012
- Chris P. Bacon
- Lansing MI
- 1,467
It's been a quiet summer for the shitbird I've been throwing parts at what I think is an electrical issue. I took the car to work one day and out of nowhere it started to completely lose power for a split second. The gauges would all drop to zero and it would buck like it lost all power for a split second. Ended up making it to work but as I pulled into the parking lot the car just shut off. It would crank but not fire, and the pump was not making any priming sounds. I had it towed home and rewired the fuel pump with an aftermarket relay and all new (bigger) wiring. It fired right up but died again on the test drive I got it back home and tried bypassing the fuel pump trigger wire to see if that was the cause, still doing it. I've also replaced the crank angle sensor, plugs, and wires but still nothing.
The wiring in my car has always been a nightmare so i've finally bit the bullet and bought a new swap harness from BP-Automotive last week so HOPEFULLY that fixes the issue, but at this point i'm not to confident. The SES light flickers on for a split second randomly while driving but the car is not giving me any codes to work with so i'm just throwing money at it at this point.
'94 Formula 6spd
