Results 21 to 30 of 344
Thread: Lets do this again version 2.0
01-23-2013, 12:21 PM #21"The Rock"
01-23-2013, 12:38 PM #22
Thanks guys.
Bersaglieri, I will send you a PM before I officially put the intake up for sale to give you first dibs on it. I just want to take some good pics, and figure out how much I want for it. It will be hard because I bought it for a pretty penny, then added vacuum lines, then had to have it modified to clear the hood (as on top of a super Vic efi intake it did NOT clear the hood when I got it). At that point I had more than $1,000 in the thing. Then later as I showed, I had some of the weaker welds redone when it split. I'm not going to ask anything close to $1,000 for it, but its still worth quite a bit (especially since you can't buy them anymore), and I need to sit down and figure out a fair price for it.
Popo, I don't want to go with the AFR 210's. My AFR 180's were fully CNC'd by TPIS which was a top dollar ordeal back in the day (it showed too with the added CFM). Then when I rebuilt the motor for boost, the performance shop hogged them out even further. I don't think the AFR 210's really flow that much better than my hogged out 180's honestly. At least not enough to warrant the expense and work to upgrade to them over what I have. If everything else is meant for high volume, I need to get something a bit bigger for the heads. The 227's although expensive with offset rockers needed, are what I want. I can get a good set of rockers from Harlan Sharp for around $430, and I will also need new pushrods. The springs I may be able to downgrade for free depending on what I need, so it shouldn't be crazy, but its not going to be cheap.1995 Z28 - disfunctional now, perhaps insane after its "treatment"
01-23-2013, 12:41 PM #23"The Rock"
Ok, I wasnt saying to get the 210s, I thought KLINE was selling 227s till I looked to get you the link. The Off set rockers will do the trick also, but when I spoke to AFR (1126 eliminators) their primary choice was the shaft mounts, although they suggested JESSEL.
You know there are bigger AFRs than the 227s now also... I think Tony S is running them... 23X.
01-23-2013, 12:45 PM #24"The Rock"
h yeah, and are your 180s LT4 or LT1 set up now?
01-23-2013, 12:49 PM #25
Gotcha.
180's only came ready for LT1's to my knowledge. Mine are for an LT1.
Which set of 227's did you go with? The race ready 1076's or the competition 1126's? Where can you get 23X's? AFR doesn't show anything larger than 227's on their website. At least not for SBC LT. For SBC heads they offer up to a 245, but they state right on their website it is for an L98 style head (LSX).
Also, I was going to start another thread on this but might as well ask it here if anyone knows; can I still use my LT4 valve covers with AFR 227's?Last edited by CALL911; 01-23-2013 at 12:54 PM.
01-23-2013, 12:52 PM #26
Ok, there is a lot of talk about heads with little information. How about some info on the whole setup especially the camshaft. There is alot more than AFR out there and if your in the AFR227 budget you've got LOADS of options. Let's get the details on the table and then talk about what the better routes are.
It's hard to compare the ported 180's with 210's [either Race Ready or Eliminator] without concrete data on where the 180 stands on actual port size and flow number. That's not the end all, but that data will be a start on figuring out where to go.Last edited by Bersaglieri; 01-23-2013 at 12:55 PM.
1994 Z28 383ci - Jake's 4L80 - Moser 9" [LE2 heads and LE cam - 121mph @5500DA]
01-23-2013, 12:55 PM #27"The Rock"
Mine are the 1126 eliminators which are LT4 design, hence why I am running the intake that they call the door stop, lol
I was concerned that if you got them you would not realize and you would have to have intake work done again, because since your 180s are LT1 design your intake was made accordingly.
With that being said, Im not sure where to find 23x... but maybe Tony S can help you.. I swear I remember them being 235s or 237s..... but I dont know much more.
Finally , yes, the VCs can be changed between the two, in fact the nice thing about the 227s I got, is they allow either perimiter or center bolt mounting which opens up more options for VCs, but if you run center bolts, fill the perimiters with silicone...ask me how I know. lol
The only reason I jumped up to the tall CANTONs was the TD shaft mounted rockers are HUGE, and would not fit under my old valve covers, so as long as your rockers are not that big you should be ok..... (I dont know anything about the size of the off set rockers), sorry.
01-23-2013, 01:04 PM #28
My cam specs: Custom Camshaft 244/254 @.050 , .578/.578 lift, 114 LSA. My AFR 180's where put on a flow bench. I need to dig up the paperwork (if it can be found) and see the actual flow numbers. But, I believe they flow benched at a little under 300 cfm.
The intake will have to be taken off anyways and ported again to be matched to whatever heads I will go with. The can be made to work with an LT4 head at that time.
When you say VCs do you mean "valve covers"? If so you are saying I can use my LT4 valve covers?1995 Z28 - disfunctional now, perhaps insane after its "treatment"
01-23-2013, 01:07 PM #29"The Rock"
01-23-2013, 01:13 PM #301995 Z28 - disfunctional now, perhaps insane after its "treatment"
