Results 1 to 10 of 63
Thread: stock heads + boost
12-17-2012, 09:10 PM #1
stock heads + boost
I just wanted to see how much are the hp limits of stock unported heads.
I' ve have had my build stopped because i cant afford good flowing heads "2,000"
My plans are turbo 383 street/strip 600-700hp.I already have an all forged eagle
rotating assemble and almosts done bottomend.Or maybe someone can point me to
a good cheap plce to get my heads ported
12-17-2012, 09:22 PM #2"Project Storm Trooper"
- Tony
- 93 StormTrooper Z28
- Rapid City, SD
- 4,810
untouched stock heads will really hurt you, but Lloyd Elliott and Advanced inductions both do great work with heads for good prices.
Official Member of $30k Club - Work in progress1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
1987 Iroc-Z - Stock Summer DD
12-17-2012, 09:24 PM #3Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
LE can port your heads for under two grand, easily. But even ported those heads will choke the 383 down at higher RPM's. You'll find your HP limitation in the heads.
12-17-2012, 09:32 PM #4
What horsepower level have yall seen LE heads go up to before they start choking?
94 Z28 TURBO BUILD in progress
12-17-2012, 09:45 PM #5
I looked at the LE website and the price is 1300 for the le2 heads.Is that porting my heads or is that
new stock heads?94 Z28 TURBO BUILD in progress
12-17-2012, 09:47 PM #6"Project Storm Trooper"
- Tony
- Rapid City, SD
- 4,810
that's porting your heads, i can vouch for his work it is second to none.
12-17-2012, 09:55 PM #7
So many turbo builds going on lol.
I went with LE stuff. He's a great dude, awesome support, and amazing work. I wouldn't trust anyone else with porting.
12-17-2012, 10:04 PM #8
I plan on attempting to blow the stock heads off my motor.
12-17-2012, 10:05 PM #9
Im thinking the le2 heads are in my budget.Now I need to figure out if the cr is going to be
low enough.I have -31 dished and stock deck height.Im going to see if i can figure it.
Im looking to get 9.5-1 or alittle less.Thanks for the direction.94 Z28 TURBO BUILD in progress
12-17-2012, 10:07 PM #10
i run a stock valved lt4 head and my car has already made over 600 on a junk built 350ci motor... i now have a 383 with the same heads and itll make more than low 600's...
1997 SS- 30th #80 SS #455 383, F1A, nitrous
http://www.gmhightechperformance.com...ler_ghtp_1203/
1995 Z28- 14:1, 355, Beer can on 4 wheels.
