Results 1 to 1 of 1
    Default 2014 LT1 Engine.
    This section will be for discussions pertaining to the 2014-20XX LT1's External Engine Tech.
    The new LT1 is the third engine in the Corvettes history to be so-named, with previous versions introduced in 1970 (Gen 1) and 1992 (Gen 2). All iterations of the LT1 and all Small Block engines have shared a compact design philosophy that fosters greater packaging flexibility in sleek vehicles such as the Corvette.
    ■Advanced technologies including direct injection, active fuel management, continuously variable valve timing support advanced combustion system
    ■Preliminary output of 450 horsepower (335 kW) and 450 lb.-ft. of torque (610 Nm)
    ■Helps deliver estimated 0-60 performance in less than four seconds and best-ever fuel economy in the Corvette
    DETROIT When the all-new 2014 Chevrolet Corvette arrives late next year, it will be powered by a technologically advanced, racing-proven 6.2L V-8 delivering an estimated 450 horsepower and helping produce 0-60 times in less than four seconds.
    The new Corvette LT1 engine, the first of the Gen 5 family of Small Block engines, combines several advanced technologies, including direct injection, Active Fuel Management and continuously variable valve timing to support an advanced combustion system.
    Our objective for the development of the all-new LT1 was to raise the bar for performance car engines, said Mary Barra, senior vice president, global product development. We feel that we have achieved that by delivering a true technological masterpiece that seamlessly integrates a suite of advanced technologies that can only be found on a handful of engines in the world.
    What makes this engine truly special is the advanced combustion system that extracts the full potential of these technologies. The art and science behind that combustion system make the Corvette LT1 one of the most advanced V-8 engines in the world, said Barra.
    Output, performance, and fuel economy numbers will not be finalized until early next year, but the new LT1 engine is expected to deliver:
    ■The most powerful standard Corvette ever, with preliminary output of 450 horsepower (335 kW) and 450 lb.-ft. of torque (610 Nm)
    ■The quickest standard Corvette ever, with estimated 0-60 performance of less than four seconds
    ■The most fuel-efficient Corvette ever, exceeding the 2013 EPA-estimated 26 miles per gallon on the highway.
    The Holy Grail for developing a performance car is delivering greater performance and more power with greater fuel economy and thats what weve achieved, said Tadge Juechter, Corvette chief engineer. By leveraging technology, we are able to get more out of every drop of gasoline and because of that we expect the new Corvette will be the most fuel-efficient 450 horsepower car on the market.
    Advanced combustion system optimized with 6 million hours of analysis
    The Corvette LT1 represents the most significant redesign in the Small Blocks nearly 60-year history building on its legacy to make one of the worlds best engines even better, said Sam Winegarden, vice president, Global Powertrain Engineering. More than just great horsepower, the LT1 has been optimized to produce a broader power band. Below 4,000 rpm, the torque of the Corvette LT1 is comparable to that of the legendary, 7.0L LS7 out of the current Corvette Z06. The LT1 is a sweetheart of a power plant and drivers will feel its tremendous torque and power at every notch on the tachometer.
    Increased power and efficiency were made possible by an unprecedented level of analysis, including computational fluid dynamics, to optimize the combustion system, the direct injection fuel system, active fuel management and variable valve timing systems that support it. More than 10 million hours of computational analysis were conducted on the engine program, including 6 million hours (CPU time) dedicated to the advanced combustion system.
    Direct injection is all-new to the engine architecture and is a primary contributor to its greater combustion efficiency by ensuring a more complete burn of the fuel in the air-fuel mixture. This is achieved by precisely controlling the mixture motion and fuel injection spray pattern. Direct injection also keeps the combustion chamber cooler, which allows for a higher compression ratio. Emissions are also reduced, particularly cold-start hydrocarbon emissions, which are cut by about 25 percent.
    Active Fuel Management (AFM) a first-ever application on Corvette helps save fuel by imperceptibly shutting down half of the engines cylinders in light-load driving.
    Continuously variable valve timing, which GM pioneered for overhead-valve engines, is refined to support the LT1 AFM and direct injection systems to further optimize performance, efficiency and emissions.
    These technologies support the all-new, advanced combustion system, which incorporates a new cylinder-head design and a new, sculpted piston design that is an integral contributor to the high-compression, mixture motion parameters enabled by direct injection.
    The LT1 head features smaller combustion chambers designed to complement the volume of the unique topography of the pistons heads. The smaller chamber size and sculpted pistons produce an 11.5:1 compression ratio, while the head features large, straight and rectangular intake ports with a slight twist to enhance mixture motion. This is complemented by a reversal of the intake and exhaust valve positions, as compared to the previous engine design. Also, the spark plug angle and depth have been revised to protrude farther into the chamber, placing the electrode closer to the center of the combustion to support optimal combustion.
    The pistons feature unique sculpted topography that was optimized via extensive analysis to precisely direct the fuel spray for a more complete combustion. The contours of the piston heads are machined to ensure dimensional accuracy essential for precise control of mixture motion and the compression ratio.
    Race-proven legacy, state-of-the-art performance
    The first Small Block V-8 debuted in the Corvette in 1955. It displaced 4.3L (265 cubic inches) and was rated at 195 horsepower, drawing air and fuel through a four-barrel carburetor. Five years later, V-8 power helped Corvette secure its first victory at the 24 Hours of Le Mans.
    In 2012, the Small Block-powered Corvette Racing C6.R beat Ferrari, BMW and Porsche to sweep the drivers, team, and manufacturer championships in production-based American Le Mans Series GT class. These championships make Corvette Racing the most successful team in ALMS history, with a total of 77 class wins, eight drivers championships, and nine manufacturer and team championships since 2001.
    The engine requirements for a production car and a race car are remarkably similar, said Jordan Lee, Small Block chief engineer and program manager. In both cases, you want an engine that is powerful and efficient, compact and lightweight, and durable. That combination is what made the original Small Block so successful. Today, the introduction of state-of-the-art technologies and engineering makes one of the best performance car engines in the world even better.
    As an example, the new LT1 engine is 40 pounds lighter than a competitors twin-turbo 4.4L, DOHC V-8 with similar output. That weight savings not only improves the Corvettes power-to-weight ratio, but also contributes to a near-perfect 50/50 weight balance for enhanced steering response and handling.
    The new LT1 is also four inches shorter in overall height than the competitive DOHC V-8. That also improves handling by lowering the center of gravity while enabling a low hood line contributing to the Corvettes iconic profile, as well as ensuring exceptional driver visibility.
    The power and efficiency of the Small Block V-8 are hallmarks of Corvette performance, said Lee. But, the compact size and great power-to-weight are just as important for the overall driving experience. The all-new LT1 will play a huge role in making the all-new Corvette a world-class sports car, in terms of technology, performance, and refinement.
    Attachment 12931
