Results 1 to 10 of 36
Thread: Boost questions
11-21-2012, 06:22 PM #1Lurker
- 2000 camaro v6 96 camaro ss
- springfield, mo
- 60
Boost questions
Hey every body Im doing my first boost build and my bases will be fourty over with stock stroke. Im using h beam rods and - 22 cc pistons all of which are forged I will be around 9 to 1 cr. How much boost could I run safely? Also what does every one use for their oil feed line?
11-21-2012, 08:48 PM #2Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
Blower or turbo? 9:1 is pretty good for a compression ratio for a lot of boost. Do you have any block modifications done such as O-Ringing?
11-21-2012, 09:15 PM #3The Wrench
- May 2009
- Chile
- 1994 9C1 6SPD
- South Jersey
- 1,942
Forged crank? 4 bolt mains?
ASE L1 Master Certified Tech's 9C1 T56. Yeah she's got a big butt. But watch her move it.
R.I.P. Z8
11-21-2012, 09:28 PM #4"Project Storm Trooper"
- Tony
- 93 StormTrooper Z28
- Rapid City, SD
- 4,810
need more info on your plans...
Official Member of $30k Club - Work in progress1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
1987 Iroc-Z - Stock Summer DD
The Following User Says Thank You to CamaroZGuy For This Post:
11-21-2012, 09:59 PM #5"The Rock"
What all of them ^^^^^
Asked....
Larry (Popo8) Co-owner
LTXtech.com
11-21-2012, 10:00 PM #6Lurker
- springfield, mo
- 60
the crank is forged and im going to go turbod its a two bolt main and im considering studing the heads
11-21-2012, 10:06 PM #7"Project Storm Trooper"
- Tony
- Rapid City, SD
- 4,810
if you stud the bottom end, and its all forged i would say 15-18psi, any more and you would want to o-ring.
11-21-2012, 10:16 PM #8The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Do you know what a studded 2 bolt main block is good for in terms of horsepower? Not to hijack but im pretty much in the same boat as the op other than I'm running a roots blower.
11-21-2012, 10:19 PM #9"Project Storm Trooper"
- Tony
- Rapid City, SD
- 4,810
IIRC, 500ish at the flywheel.
11-21-2012, 10:23 PM #10The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
Uh oh....
