Results 1 to 10 of 401
10-03-2012, 08:46 PM #1"Project Storm Trooper"
- Tony
- 93 StormTrooper Z28
- Rapid City, SD
- 4,810
"Project Storm Trooper" S/C Build
so since my last thread got all sorts of mucked up with B.S i requested to get it locked.
So here it is the version2 build thread. clean, fresh and happy!
Induction-
Type: Procharger P1SC
Boost: 8-12 PSI
Intercooler: FMIC
BOV: BIG RED ATI
Meth/Water: Snow Performance stage 2
Engine-
Block: 383ci Stroker by Clayton Racing
Compression: 9.8:1
Crankshaft: Dragonslayer 3.750
Connecting Rods: Compstar 6"
Pistons: CP -16cc
Cylinder Heads: AFR 210's
Camshaft: L.E. custom grind
Rocker Arms: CC 1.6
Intake Manifold: LT4
Ignition/Computer: EFI 24X
Headers: PACESETTER LTs
Exhaust: Borla
Cooling System: STOCK w/EWP
Fuel-
Pump: 340lph
Injectors: 60#
Rails: STOCK
Drive train/Transmission-
Transmission: T56 swap
Clutch/Converter: Spec 3+/F1racing chromoly Flywheel
Driveshaft: Dennys Nitrous Drive shaft
Rear Axle: Moser 9" 4.11's spool
Chassis-
Front Suspension: QA1/300# spring, UMI K-member, control arms
Rear Suspension: Moog springs, QA1's, Spohn panhard/LCA, UMI relocation brackets, UMI chassie mount Tq arm
UPDATE!
Official Member of $30k Club - Work in progress1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
1987 Iroc-Z - Stock Summer DD
The Following User Says Thank You to CamaroZGuy For This Post:
10-03-2012, 09:16 PM #2InActive Member
- Jan 2012
- 1997 z28 383 stroker
- oklahoma city,ok
- 2,859
sweet man looks awesome BTW what valve covers are those?
You can't pee on what you can't touch (chevy)
10-03-2012, 09:20 PM #3"Project Storm Trooper"
- Tony
- Rapid City, SD
- 4,810
10-03-2012, 09:25 PM #4"The Rock"
10-03-2012, 09:27 PM #5"Project Storm Trooper"
- Tony
- Rapid City, SD
- 4,810
depending on how money flows (still need some stuff) im shooting for a Christmas/New Years key turn....
10-03-2012, 09:29 PM #6"The Rock"
10-03-2012, 09:31 PM #7"Project Storm Trooper"
- Tony
- Rapid City, SD
- 4,810
10-04-2012, 04:05 AM #8
Looks like that is gonna be a fun build to drive gl on your build.
97 Comp T/A #161 out of 164 LT1 383 stroker, TPIS/AFR heads, JE pistons, 9.3cr, extreme energy comp cams 224/230, Howards billet rods 5.85, Callies dragon slayer crank, 2 bolt mains converted to 4 bolt billet, Mildon oil pump, MSD opti, 6AL, boost retard, HVC 2 blaster coil, BBk 58mm, 50lb injectors, 3200 stall. Took 600b off to help fund twin turbo.
10-04-2012, 07:56 AM #9InActive Member
- Jan 2012
- oklahoma city,ok
- 2,859
Do you know if they are better than the cantons?
10-04-2012, 07:57 AM #10InActive Member
- Jan 2012
- oklahoma city,ok
- 2,859
