    Jul 2012
    95 Z28 6 speed
    Springfield Tn
    Default stock head gasket
    Anybody know what the stock thickness is on the head gasket. I'm trying to figure out my compression ratio. I've had .010 off the heads and .007 on the block deck. I think stock gasket is .058. The gaskets I have now are .058 they came with my gasket kit. I'm wanting to get 11:1 or better, but I'm pretty sure I won't get it with theses gaskets. I don't know if I can get close to that or not with thinner gaskets.
    Jan 2010
    Southern NJ
    What motor do you have?
    You will need to know combustion chamber volume as well to determine your compression.
    -Joe-
    95 T/A.
    Aug 2009
    Kyle
    '95 Trans Am
    Elizabethtown, Kentucky
    cut a shim gaskent to work.
    Kyle
    just ur everyday slow LT1. wanna try her out?
    Jul 2012
    95 Z28 6 speed
    Springfield Tn
    Sorry, its a 1995 z28 camaro. Stock heads, bore and stroke. I need to get on a computer and do my sig, can't do it on mobile for some reason. Gonna run a cc306 with some port work on the heads. I'm sure ill catch some flack about the stock bore but oh well. Lol
    Jul 2012
    95 Z28 6 speed
    Springfield Tn
    I figured about 1.3-1.4 cc's have been removed off the heads, and with the heads and block together there's almost 3cc's gone.
    Jul 2012
    95 Z28 6 speed
    Springfield Tn
    How do i go about figuring out combustion chamber volume?
    Jan 2010
    Southern NJ
    -Joe-
    95 T/A.
    "Project Storm Trooper"
    Tony
    93 StormTrooper Z28
    Rapid City, SD
    Felpro 1074, its a. 039 crushed thickness gasket. And its a good gasket.
    Sent from my DROID RAZR using Tapatalk 2
    Official Member of $30k Club ​- Work in progress
    1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
    1987 Iroc-Z - Stock Summer DD
    Mar 2009
    IN
    ^what I run. Good gasket esp for the price.
  10. #10
    Jul 2012
    95 Z28 6 speed
    Springfield Tn
    Thanks for the info.
