Results 1,141 to 1,150 of 1156
Thread: Project Rainbow Unicorn 2013
02-24-2024, 05:39 PM #1141
New fuse panel
Some front bumper work
Rear area
Under dash
Getting there
As of now, power windows, power locks, power side mirrors, turn signals, brake signal, hazards all work. Still need to wire in the headlight switch for headlights and interior lights. Lots of clean up still needed but slowly chipping away.Correlation does not imply causation.
The Following 4 Users Say Thank You to shownomercy For This Post:
02-24-2024, 05:53 PM #1142Xtreme Member
- 7,266
02-26-2024, 07:51 AM #1143Xtreme Member
- Nov 2008
- PA, USA
- 2,438
I feel the need to donate some friction tape and loom.
02-26-2024, 11:11 AM #1144
02-27-2024, 09:58 AM #1145Xtreme Member
- Nov 2008
- PA, USA
- 2,438
02-28-2024, 09:44 AM #1146
Cool stuff on your control wiring. I can appreciate it being wired industry style. Maybe I missed it, but why did you decide to completely re-wire the car?
Was it just a continuation of removing the stock PCM, BCM, ABS, etc.,etc.?
02-29-2024, 07:29 AM #1147
Yea the last of the factory stuff was hacked to hell after years of younger me not knowing any better. Circuits didn't follow oem schematics so troubleshooting was a nightmare and I wanted to finish pushing for a clean slate electrically across the car.
Also I have severe car adhd so any reason to try new things is jumped onCorrelation does not imply causation.
The Following 3 Users Say Thank You to shownomercy For This Post:
02-29-2024, 10:20 AM #1148
Gotcha, That factory wiring is sized so borderline that it gets too hot and the insulation gets brittle too.
So they got a name for this hotrod habit we have.
03-26-2024, 06:38 PM #1149
Hour a day, or something.
Since the "racecar" push button start panel is no longer needed, replaced it with this creation. USB ports are for holley and radio. 8-)
DT connector, EVERYTHING.
Yes, I know I drilled one extra hole.Last edited by shownomercy; 03-26-2024 at 06:41 PM.
The Following 5 Users Say Thank You to shownomercy For This Post:
03-26-2024, 09:35 PM #1150
Great job on your re-wire. Some people don't realize how much effort goes into ALL those connections.
This is coming from a old retired electrician.'97 SS SLP,T56, Spec stage 2+ clutch,385 stroker,AFR210,XFI292,Moser 12 bolt eaton posi 4.10's. NO traction til top of 3rd gear.
