Page 105 of 105 FirstFirst ... 55595101102103104105
Results 1,041 to 1,045 of 1045
  1. #1041
    Been cruising it lately and found that the low oil light comes on more than I like. Unsure of if I am running too little oil, or its just a lousy pan.
    At some point, I should pull the damn pan lol
  2. The Following 2 Users Say Thank You to shownomercy For This Post:
  3. #1042
    Some tame 2 step action
  4. The Following User Says Thank You to shownomercy For This Post:
  5. #1043
    Also wired in my boost dial, this way I can change the tune on the fly
  6. The Following 3 Users Say Thank You to shownomercy For This Post:
  7. #1044
    Finally ditched the dream of a draft style PCV can (pulls vacuum between air filter and turbo inlet) [Doesn't work too well once you have a very efficient air filtyer]
    Used one of the ports on the intake
    Check valve so I don't pressurize the catch can.
    Pulls a lot of vacuum across the top end of motor, so thats a start.
  8. The Following 2 Users Say Thank You to shownomercy For This Post:
  9. #1045
    Boredom hits hard
