Results 11 to 17 of 17
Thread: Cam Advice
11-16-2011, 07:35 AM #11
That cam on a stock motor will need some high rpms to get anything out of t and then you will be past what your heads will deliver.
I have a custom grind that is slightly smaller than that. I am running it on a stock bottom end with touched up heads and it runs good. I got it from Futural Motorsports.1996 ss m6 white and black hardtop
custom everything, cam, heads, 8.8 w/4.10s, duals you name it.
11-16-2011, 08:37 AM #12
OP, you're getting some good advice here. That cam is pretty big to start off with. You will need the heads, valvetrain, stall, gears, etc to support a cam that size.
What part of Louisiana? I'm in Baton Rouge.
11-16-2011, 04:22 PM #13
Thanks for all the advice, I guess a cam won't be the first of my worries then. Headers and gears, here I come.
I'm in Shreveport
11-16-2011, 06:36 PM #14VIP Member
- Nov 2010
- CHRIS
- 94 CAMARO.
- Biloxi, MS
- 1,342
that's a good cam for making big power. we have ran 8.96 with it in a 383 and a ysi.
11-16-2011, 06:46 PM #15
11-16-2011, 11:23 PM #16
Coming from a person that was going to just swap in a cc503, do the whole works and take it nice and easy on the build. From what i thought was just going to be a simple cam and valvetrain upgrade ended up being a whole engine rebuild, heads ported, custom cam, etc...
The way I see it is "if im this far into it, i mind as well do..."
11-17-2011, 06:34 AM #17VIP Member
- Nov 2010
- CHRIS
- 94 CAMARO.
- Biloxi, MS
- 1,342
