Results 11 to 20 of 47
Thread: 383 stock heads???
10-30-2008, 11:48 PM #11
The le1, le2 and le3 are different levels of stock ported heads on elliotsportworks.
1997 Trans am- M6- Ebay Longtubes, Summit X pipe with Magnaflows, CAI, Adj LCAs with relocation brackets, Comp engineering shocks, Competition stage 2 clutch.
10-30-2008, 11:49 PM #12
10-30-2008, 11:50 PM #13
http://www.advancedinduction.com/AiProductsLT1.html
Heres a link to the lt1 heads.1997 Trans am- M6- Ebay Longtubes, Summit X pipe with Magnaflows, CAI, Adj LCAs with relocation brackets, Comp engineering shocks, Competition stage 2 clutch.
10-30-2008, 11:50 PM #14
10-30-2008, 11:54 PM #15
10-31-2008, 04:05 AM #16
The stock heads when ported will start to fall off at about 550 HP. The intake can take as much as you can throw at it (it's already a good design) but the more HP you make, the more it will hold you back without porting.
I got my LE2 heads used with 1k miles on them for $1100.1996 Camaro Z28
LE2 Heads, LE ported intake, LE emissions cam, Comp Pro Mags, 37# Injectors, 58mm TB
M6 Conversion, T56 by Six Speeds Inc, RAM Powergrip, McLeod Adj. MC, B&M short throw
Kooks LTs, Loudmouth, K&N CAI, MSD (wires, coil, 6AL), BMR PHR, UMI SFCs
10-31-2008, 09:11 AM #17
Heads make the power in all cars not matter LT1 or LS1 or SBC....you can use your stock heads and be fine but I would either do bottom end and then save for the best heads you can afford. I think with stock heads you would be somewhere around the mid-lower 300 with stock heads.
My 355 with stage 2 heads/cam made 390rwhp. Maybe look at spending less on the shortblock and add in some heads/cam
10-31-2008, 09:36 AM #18LTX Member
- 1997 Camaro SS
- Overland Park, Kansas
- 5,172
Don't expect much more than 360-380 rwhp NA through stock heads.
-Eric
10-31-2008, 11:26 AM #19
Yeah nothing wrong with bolting the stock heads on for awhile. Like you said, just to get by for awhile. BTW, i made WELL over 500whp with stock unported heads on a 355 @15psi. One big thing to do is port match the intake while its off, should only take an hour and pick you up a little power anyway. Its more fun to have a quick car that you can drive than a really fast one sitting in the garage with no heads on it.
94 T/A- forged 355 LT1, bone stock heads, Vortech YSi w/10-rib, FMIC, T56, 9"
http://s214.photobucket.com/albums/cc192/Grrh77/
10-31-2008, 03:05 PM #20
That's all I need to hear.
I'm not going to go through the money/effort to port the heads when 475-500WHP is my goal anyways. I thought that level would be attainable on 12psi with a cammed 383 through stock heads, a 6 speed, and 10 bolt still.
Thanks for the insight!
'04 K3500 DMax, '01 FXDX, '94 Z/28 M6, '91 Sonoma, '55 Bel Air
