Results 21 to 30 of 31
01-09-2011, 08:39 PM #21Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- Elizabethtown, Kentucky
- 3,033
its what im running
Kyle
01-09-2011, 11:39 PM #22
how hard is it to modify them?? is it that much of a difference over stock or the impala gaskets to use these gaskets? im ganna be doing a full overhaul and wouldnt mind squeezing a lil extra power outta it over a gasket if i can..
1991 Camaro RS convertible/sold.. 86 TRANS AM with 8 point cage and LT1 SWAP in PROGRESS
swap thread:
http://ltxtech.com/forums/showthread...tible-lt1-swap
01-10-2011, 01:22 AM #23Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- 3,033
its not hard at all to mod them. maybe 5 min each.
Kyle
01-10-2011, 09:20 AM #24
What's involved in modding them I guess all I would have to do is lay the lt1 gasket over the sbc gasket n trim what's needed? Is it worth it power wise?
swap thread:
01-11-2011, 11:00 PM #25VIP Member
- Jan 2009
- Paul Edwards
- 1993 Camaro Z28
- Port Charlotte FL
- 2,666
1995 Formula 383/t56 gone
1993 Camaro Z28, forged, TFS heads, solid roller, prosystems carbed, t56 swapped spec 3+
"Nitrous is like Tara Reid with an STD. You want to hit it, but your afraid of the consequences"
01-11-2011, 11:38 PM #26Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- 3,033
01-12-2011, 01:32 AM #27
hmm might look into that since im buying gaskets anyway
swap thread:
01-12-2011, 10:33 AM #28
I am late to this however I see no problem with the Impala head gasket replacement. You are
not replacing the pistons or rods with aftermarket and you are not porting the heads or even changing the valve size...... So the car will remain a bolt on car!!!!!!!
01-13-2011, 09:58 PM #29
What are the gains with the shim?? Im gonna use them soon.
01-14-2011, 02:17 AM #30VIP Member
- Jan 2009
- Paul Edwards
- 1993 Camaro Z28
- Port Charlotte FL
- 2,666
its ether 4% or 6% increase per point in compression i believe it is 4%. with that being said its 1 point and you prolly have 280ish so get to calculating.
