Results 1 to 10 of 10
    Oct 2008
    Komifornia
    Default Tunning and dyno results.
    So, yesterday I was at Fresno Performance from 8 am the 4:16 pm.
    Tunning was done by Chuck Summer's of Whipple Industries.
    Stock 143k mile short block. Stock fuel pump. Stock 48mm TB. Stock clutch, stock 3.23's. LE2 heads, LE ported intake, LE 223/230 .565/.565 112CL. Aeromotive FPR, Pacesetter mids, Magnaflow cat and cat back. Fastbird 4 wire 02 conversion, Full emissions. 160 stat, 32lb injectors, heavy ass 1.6 SS roller rockers.
    The car more than met my goals in terms of power production, But the biggest thing is the driveability that Chuck was able to do. I would highly recomend him for your tunning needs if you are anywhere near central CA.
    I will post the sheet in a few days when I have time to get it scanned into the computer.
    382 RWHP and 351 RWTQ on a Dynojet 248.
    Marc
    93 LT1 M6, LE, 223/230 .565/.565 112, Stg2 heads, Ported intake, 32lb injectors. Pacesetter mids. 1.6RR Tunned by Chuck Summer's. 382/351
    2000 F350 7.3 diesel, BTS auto CC Dually 4X4. Way to many parts. 689rwhp/1450ftlb's
    Feb 2010
    SIN CITY
    nice numbers what did he use to tune your 93 computer?
    93 Z28 M6- PACSETTER LT'S/ HOOKER CB OR-Y/ WEIGHT WATCHERS DIET / UMI STAGE 5 FRONT SUSP,T/A RELO,PHB &T/A/ HOTCHKIS STB,LCA'S/ MSD OPTI &6AL/ STILL IN THE WORKS
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Very nice results! I'd like to see a bit more TQ with that small of a cam, but very very stump pulling tq curve none the less.
    Nov 2010
    Sacramento
    very nice numbers for the parts u have there...
    F-BODY MOB
    Apr 2010
    Oshawa, Ontario
    Those are some great numbers for a stock tb, mids, and mechanical waterpump. I made 376rwhp/377tq at 6k rpm with a runout issue. Hope to have it fixed and make a full pull to 6500rpm and make up some power. Still a kick in the balls on my side running a 58mm tb, ewp, and longtubes in the same power neighbourhood.
    1997 Trans Am WS6 - 355/M6
    Built 355, LE1 Ported Heads/Intake, CC306, Full Suspension, 4.10s
    1994 Fire-Am LTx/M6 (378rwhp/380tq)
    EFI Connections 24x, Forged 355, AFR 190s, LE1 223/230, Full Suspension, 4.10 Gear
    Oct 2008
    Komifornia
    Thanks guys. Been a while since I have checked in. Car is still running good. Have had a few small problems lately. I do have a Holley 58 mm TB to throw on that has the N20 ports for a dry shot and I did put an MSD digital 6 ignition box on. The ignition box smothed the motor out even a bit more and may have picked up a few more pony's according to the butt dyno. Got to get it back to the dyno for a bit more tweeking and to lean out the idle a bit, really close on my HC numbers for smog. Stock fuel pump died and had to change it out with a 255 pump. Not bad for 160k miles.
    MAD ABOUT LTX's
    Jun 2012
    Mike
    1993 Camaro Z/28 A4 2006 Chevrolet Avalanche 1500 1970 Firebird Espirit, 1972 Camaro Sport Coupe
    Vallejo Ca (SF Bay Area)
    Quote Originally Posted by QWKzee93 View Post
    I too would like to know what program he used to tune the pcm since I have a 93 as well.
    If you don't stand behind our MIlitary then feel free to stand in front of them. <---- This is my oldest son (PROUD DAD HERE) Mike (just plain mad) Madman337 1993 Camaro Z/28 A4 all stock other than a muffler and LCAs @292K+ miles. 2006 Chevrolet Avalanche. 1970 Pontiac Firebird. 1972 Camaro, 1994 Corvette, ​17 Fusion Sport AWD V6 Twin Turbo
    Feb 2012
    Las Vegas, NV
    Quote Originally Posted by Madman337 View Post
    Bump
  9. #9
    Oct 2008
    Komifornia
    The 93 still use the Eprom chip that has to be flashed after the tune is written. I am not sure what he was using as I wasn't paying much attention. I know he was plugged into the OBD I port for datalogging, but he also had an emulator plugged into the PCM an was doing real time tunning changes on the fly. When he was done with the tunning, he flashed my stock Eprom with the final tune. I think the emulator was from TTS, it was old that is for sure. I just remember him opening the trunk of his car and pulling two big boxes of cables and conectors to find the right stuff.
    I am trying to convince Steve Cole of TTS to tune my car. He said he might be able to do it if I leave the car with him for a month.
  10. #10
    MAD ABOUT LTX's
    Jun 2012
    Mike
    Quote Originally Posted by uncool View Post
    Ok cool I have a couple of friends that want a tune on their stuff too so I am going to try it myself and see what happens.
