Results 1 to 10 of 15
Thread: Going for eights Sunday
10-18-2008, 06:37 PM #1
Well the fogger is actually wired now. The car has left on a .075 jet without any problems. I have a .028 jet in the fogger. I'm putting the 100hp jets back in the plate. My intentions are to make a pass on the small jets. Then try to leave on the fogger with a .6-.8 delay in it. If the plugs look good after a few passes its time to leave on the a .055 or .057 then bring in the fogger in 1.2 seconds out and see what it does.
I did manage to get the afco front shocks on. I also put some new tires on the car. MT sportsmans on the front and Hoosier QTP's on the back. I put an actual 12" of rubber out back on each side with the 28x14.5's. The tires are about an inch shorter then the MT slicks I've been running.
Whats the bets on what happens?So far 10.576 @ 128.64 on a 1.563 short time. N/A.8.957 @ 151.60 on a 1.349 60' timeTHE FIRST 8 SECOND NITROUS POWERED LT1
10-18-2008, 06:57 PM #2
If all goes well, Id say you have it.
Nick
10-18-2008, 07:46 PM #3
good luck!!
Chris Close
10-19-2008, 01:13 AM #4
Best of luck to you for sure.
10-19-2008, 06:15 PM #5
Cant wait for results
Nick
10-19-2008, 07:21 PM #6
I changed shocks and tires and the car wasn't leaving straight. The second pass I had a problem at the line with a relay after getting all that worked out I was down to one kit. I can't post times right now because of a possible bet on a different forum but I did run a new best time.
Heres a couple of pics.
I didnt get a pic of the last pass but it was a 1.310 60' on the back tires I will have a series of those pics in a couple days.So far 10.576 @ 128.64 on a 1.563 short time. N/A.8.957 @ 151.60 on a 1.349 60' timeTHE FIRST 8 SECOND NITROUS POWERED LT1
10-19-2008, 08:20 PM #7
Hmmmm, any video when you post it?
10-19-2008, 08:25 PM #8So far 10.576 @ 128.64 on a 1.563 short time. N/A.8.957 @ 151.60 on a 1.349 60' timeTHE FIRST 8 SECOND NITROUS POWERED LT1
10-19-2008, 08:29 PM #9
so did you get the 8???????
we wanna know...... go see my video of my fun at grudgewars on saturday....... car ran good but it's gonna cost me....
West Coasts Fastest OEM block 4th gen
9.06@153.8 1.35 60', 10.62@127 all motor
CSM Racing Engines 383, SR, single plane, etc!!!!!
10-21-2008, 07:28 PM #10
Well I don't think the guy that called me out is going to lock in but I made 6 passes. The car went fairly straight on a .063 jet with the new shocks put a .075 jet in with 20* total timing and the car was turning right leaving the line. Had to lift once when I crossed the center line. The car was going 9.6's on the .075 jet with 1.35-1.38 60' times. After get the weigth moved back were it was needed to make the car go straight I added 1.5* timing and the car went
60' 1.310
330' 3.832
1/8 5.985 @ 113.93
1000 7.860
1/4 9.458 @ 140.25
That was the third pass on a ten pound bottle so it got a little rich. Theres more in that shot. But the PLC is going in and I'm not going to run into anymore problems with running 2 kits with one window switch, one WOT switch, plus it is going be easier to troble shoot.
I'm putting double adjustable rear shocks on the car this week. After talking to the chassis guy that built my fabbed rearend and torque arm I'm going to lower the LCA one hole to help with antisquat and lower the torque arm a little to take some of the hit back out of the tires but the year is about over here. Hopefully the rain misses us on Saturday.So far 10.576 @ 128.64 on a 1.563 short time. N/A.8.957 @ 151.60 on a 1.349 60' timeTHE FIRST 8 SECOND NITROUS POWERED LT1
