I know this is an old post, but I need help with this. I'm having a hard time knowing what exactly I'm supposed to grind off. I've grind what I I thought was the tabs and I still can't get the two pieces to separate.
you have to grind the center area flush to the knuckle, then beat the hell out of it to get it off.Attachment 39844
^^What he said, even then it's sometime a real PITA to get them to separate, especially if the shaft has a lot of corrosion or rust.
Thanks! That helps a ton. I got that part ground down but I'm still having a hard time separating the two pieces. Is there a best place to strike the shaft to get them to separate?
I've done it a few times and had to use a vice and a air hammer on the face above each crimp.
