NP I actually just got this months order as well :)
I don’t know how I feel about the products like IGL Quartz. I want to try it but it isn’t something I am use to nor know much about
IGL coatings are all professional grade and you would need to be approved to use them. When I first got into coatings I started with Carpro Cquartz. Coatings are starting to gain traction and are become more mainstream so there are a ton of fly-by-night companies jumping in and putting out terrible products. If it is something you want to get into I would recommend sticking to well known brands like Carpro, Gyeon, or Gtechniq. The biggest things with coatings are the prep work, flash times, proper leveling of the coating, and making sure you allow enough cure time in between coats. Flash times/cure times can be alittle tricky based on temperature and humidity. Generally speaking the hotter it is the less work time you will have. On the opposite end of the spectrum if it is too cold the coating will take a long time to flash/cure.
I have also seen a lot of people swearing by McKee's 37 Hydro blue. I have not used it yet but it looks very easy to use and from what I have seen works well.
All of the brands you listed receive high praise! I am working with a few companies right now in my selection process. I am leaning more towards Kenzo/IGL.
Have you seen the $10 ceramic on Amazon? A few people actually tried it and posted results in Obsessed Garage. I bought it as well to try on a set of Vette reproduction wheels I have. Because why not! Haha :)
ive seen those but dont trust them. I basically went from Carpro to IGL. Now that I am a master installer for IGL I am thinking about approaching Carpro as well for certification. My main goal right now is IDA (International Detailing Association)
sweet and clean
Suzuki GSXR 1000 after basic therapy, IGL Kenzo, and IGL Wheel. The helmet got Kenzo as well. https://uploads.tapatalk-cdn.com/201...abbfb21814.jpghttps://uploads.tapatalk-cdn.com/201...4623bd57e1.jpghttps://uploads.tapatalk-cdn.com/201...e226e4afc5.jpghttps://uploads.tapatalk-cdn.com/201...73437d5c24.jpg
'86 300ZX before and after pinstripe removal and advanced therapy. https://uploads.tapatalk-cdn.com/201...717a2a16d1.jpghttps://uploads.tapatalk-cdn.com/201...47d2c7a36a.jpghttps://uploads.tapatalk-cdn.com/201...4f588a97f5.jpghttps://uploads.tapatalk-cdn.com/201...5a3549fa1a.jpghttps://uploads.tapatalk-cdn.com/201...594f552aa1.jpghttps://uploads.tapatalk-cdn.com/201...3b4b8a1266.jpghttps://uploads.tapatalk-cdn.com/201...b727ba6e75.jpghttps://uploads.tapatalk-cdn.com/201...735baa871d.jpg
